Would like to see if someone can make integration for the Mopeka Wifi Bridge to work with Home Assistant. The sensor integrations work, but once you move the tanks away from the HA server, the Bluetooth goes out of range and makes the integration useless. Integrating the Wifi bridge would be much more useful.
So this isn’t it?
Maybe need an ESPHome Bluetooth proxy closer to the device?
I’m about to need to deal with this situation myself.
I’m ok with using ESPhome as a bridge, is that something that is possible with this add on?
im not familiar with ESPHome Bluetooth proxy, I will need to research this. I have a new situation where I am moving my HA off-premise, so the Mopeka sensors (and bridge) will no longer be in the same state. So some way to integrate this via the wifi bridge would be helpful
I’m looking for this integration too as I could not make the direct bluethooth connection works with my HA. hopefully this integration with the Mopeka wifi bridge can be developed soon.
