Mopidy media player monitor with touch controls
Hey Folks. Wanted to share a small project that I’ve made recently. Background: I’m using a Mopidy for a few years now. It is connected to a home grown Raspberry Media center, that is in turn push audio to PCM5100 DAC, and then to the commercial JVC stereo system from the 90’s.
Recently I’ve added a standalone Mopidy monitor that stands on the top and controls playback via home Assistant integration.
But let me go step by step.
Hardware is also home-grown Loud ESP board with dual MAX98357 DAC and TFT display with touchscreen, as well as few more peripherals.
The loud-esp-mopidy-monitor config is there to implement
  • media_player publishes the media player into the Home assistant, so I can use it together with the native player or Music Assistant or voice announcements.
    • Volume set up to 50% on player start. You can change that, but for me, it is too loud by default
  • display and touchscreen components configure the onboard display
    • shows the current Mopidy playback item, Artist, and Title.
    • three playback buttons allow Play/Pause track and move back and forward along the playlist via touchscreen controls
    • on the top of there is a volume indicator with two buttons to change it
    • the progress bar shows the current progress of the track
    • on the bottom there is playlist progress with the current item highlighted (first out of four)
    • current hour for practicality :wink:
  • remote_receiver exposes the IR reader. I use Samsung TV remote to control Mopidy playback and volume.
  • light component exposes onboard RGB LED for use in integrations. I light up an LED when TTS announcement is made.
  • psram enabled for smooth out playback
Currently, no component can display live track images, but it seems like it will be added soon
On the home assistant side, I did a few scripts to support touch buttons
mopidy_volume_up:
  alias: Mopidy Volume Up
  sequence:
    - service: media_player.volume_up
      data: {}
        entity_id:
          - media_player.mopidy
  mode: restart
  icon: mdi:volume-plus
mopidy_volume_down:
  alias: Mopidy Volume down
  sequence:
    - service: media_player.volume_down
      data: {}
        entity_id:
  mode: restart
  icon: mdi:volume-minus
mopidy_next_track:
  alias: Mopidy Next Track
  sequence:
    - service: media_player.media_next_track
      data: {}
        entity_id:
  mode: restart
  icon: mdi:skip-next
mopidy_prev_track:
  alias: Mopidy Prev Track
  sequence:
    - service: media_player.media_previous_track
      data: {}
        entity_id:
  mode: restart
  icon: mdi:skip-previous
mopidy_play_pause:
  alias: Mopidy Play Pause
  sequence:
    - service: media_player.media_play_pause
      data: {}
        entity_id:
  mode: restart
  icon: mdi:play-pause
mopidy_stop:
  alias: Mopidy Stop
  sequence:
    - service: media_player.media_stop
      data: {}
        entity_id:
  mode: restart
  icon: mdi:stop
Last piece is an automation that switches JVC amp on and off based on playback status with WiFi smart socket (to save electricity, old amps are quite thirsty)
I think this should also work with native media player or Spotify, but I didn’t check, since Mopidy I’m using most.
