Mopidy not in Hass.io repository?
hassio-addons - edge
mopidy
This add-on is not available on your system.
:frowning:
last version hassio
Terr, did you ever get a working version installed? If so could you share what you did?
I was trying to do the same thing, install the mopidy addon from the Edge repository.
It doesn’t seem possible on a Raspberry Pi though, the addon is not available on my system either, I guess because it’s only for Amd64 and not for Arm architectures.
I have installed the mopidy addon from the bestlibre repository, and it was successful on a Raspberry Pi, so that seems to be working, though I haven’t really tested it or used it yet.
I have also installed mopidy from the bestlibre repository. It is only available for 32-bit system. I moved to a SSD and installed Debian 64-bit and mopidy was not available for it.
Same here, using HA OS. Unfortunately, I have no clue how to setup mopidy because i cannot find any possibility to edit the mopidy.conf.
The origin of my issue is to have a working solution for multiroom spotify, which should be possible to achieve using mopidy and snapcast. Any ideas?
