I have a question.
I have 2 houses connected to one Home Assistant.
Is it possible to configure the alarm panel separately for 2 houses?
The Alarmo integration from HACS allows you to divide your home into independently alarmed areas. Since you have a single HA instance you may be able to alarm your two houses separately as different areas.
Unreal, perfect.
This is exactly what I needed.
Thanks.
