Hi all,
I have a working template sensor with the code below. I’m wondering if there’s a better way to write the IF statements. To give you a background, the sensor is a way for me to pull various location data into a single sensor. The IF statements are a way of testing i the user is within one of the predefined zones, otherwise the sensor will report an Open Street Map location instead.
- name: becks_location_amalgamated
state: >-
{% if is_state('sensor.becks_location', 'Home') %}
{{ states('sensor.becks_location') }}
{% elif is_state('sensor.becks_location', 'School') %}
{% elif is_state('sensor.becks_location', 'Sally and Stus') %}
{% elif is_state('sensor.becks_location', 'Stuart and Lyndas') %}
{% elif is_state('sensor.becks_location', 'Swimming') %}
{% elif is_state('sensor.becks_location', 'Tony and Annes') %}
{% elif is_state('sensor.becks_location', 'Ross Work') %}
{% else %}
{{ state_attr('sensor.becks_location_open_street_map', 'locality') }}
{% endif %}
Im under the assumption there may be a better way of testing if a user is inside one of the pre-defined zones, or at the very least there will be a way of tidying up the rather long ELSE IF code. I’m worried that if I rename a zone or add new ones that I may forget to update the sensor.
I’m not great at code or editing it so any help anyone can pass on is greatly appreciated
