Since upgrading to Home Assistant 0.115 (Thank you for this great release btw) I am missing the controls of climate entities in the more info dialog. Prior 0.115 one was able to set target temperature or mode in more info but now the dialog just shows the same info as you can already see before clicking on it.
I had this issue, one day it didn’t work, next day it did. Not saying it’s linked but there was an update the scheduler add-in loaded. Nothing else was done on my instance that day.
I finally found out that it was not an issue in Home Assistant. My thermostats are integrated through Homematic and the memory-card of the raspberry which works as a gateway for the Homematic-components died. While the web interface of Homematic was still running, some functions were not available. After a reboot the raspberry did not come up at all, so I had to recover the whole system with a new memory-card and a backup. After the recovery the thermostats can be controlled from the more info dialog again.
