Today there is a quite uncomplete list of device classes available for sensors. There is a PR for adding force and mass that is closed - I would like to get distance (in meters) and I guess there are some other - frequency (Hz) and maybe sound pressure level (SPL), PM2.5/10? What is the plan for this? Is there a plan for adding more sensor classes? I would not want to spend time doing a PR if there is no interest.
Some more suggestions ā¦
Sensors:
- Flow - m3/h, USGPM etc.
- Level - %, m, mm, ft etc.
- Speed - m/s, MPH etc.
Binary Sensors:
- CO - CO detected/no CO detected
- Low Flow - low flow detected/no low flow detected
- High Flow - high flow detected/no high flow detected
- Low Level - low level detected/no low level detected
- High Level - high level detected/no high level detected
- Low Pressure - low pressure detected/no low pressure detected
- High Pressure - high pressure detected/no high pressure detected
Direction or Bearing also (non-binary of course!)
Came here looking for just this. Another vote for particulate matter.
Here are some more:
- pulses
- monetary
- rain_amount
- wind_speed
- speed
- time_delta / time_period
- ppm
- power_density
- angle / rotation_angle
- color_temperature
- brightness
- length
- area
- acceleration
- capacitance
- density
- force
- frequency
- impedance
- mass
- resistance
- volume / sound_intensity
- temperature_difference (K)
- volume (mĀ³ / l)
- work (J)
There is currently a discussion and PR about adding binary_sensor device classes:
And discussions about some of the mentioned:
Ok, so there are at least some interest - I will look into reviving the PR that intended to add a few and add some more to that one then (and hope it gets in this time)!
Best regards,
/Joakim
The description of the last_reset properties of a sensor which is needed for longterm statistics talks about gas and water meter Sensor Entity | Home Assistant Developer Docs. However the device_class , which is also required for longterm statistics, for volume is not available.
In my opinion a volume device class is very common and should be suported, especially in the light of the new energy management development
There will be a gas device_class.
Now I did a PR for some of the sensor classes: Additional sensors update by joakimeriksson Ā· Pull Request #54605 Ā· home-assistant/core Ā· GitHub
Not sure that all features are there yet.
Iāll add my suggestion here:
Add ālevelā device class for binary sensor.
For binary_sensors ālevelā would be ārisingā if āonā, āloweringā if āoffā
For sensors ālevelā would be in āinā or ācmā.
My use case is I track the temperature trend of my fish tank with a trend binary sensor. If I use a device_class of āheatā or ācoldā it shows as āHotā or āColdā.
It would be nice to see āRisingā or āFallingā.
Iāll chime in as well with a request for weight (assuming itās not covered by āmassā above)
To follow wave tide, a device_class with meter will be usefull.
Can we add a generic class ?
Sorry Iāve created the topic https://community.home-assistant.io/t/long-term-statistic-for-not-listed-device-class-e-g-distance-with-meter-measurement/330533
Bandwidth (Mbps) hasnāt been mentioned jet.
There is not enough device class for the Geiger counter (ĀµSv/h).
Iām confused. Itās 2022 and we still donāt have device classes for mass, force etc.? The set of documented device classes is woeful: Sensor Entity | Home Assistant Developer Docs
Is there a way users can extend the set of device classes themselves?
I would also like to see some more device classes, it shouldnāt be too hard to add them. Especially one for distance (m).
I need one for pH as well.
