More sensors in file
Hello.
What I need to write to file: configuration.yaml If I need have in file more than one sensor?
If I have only one sensor in file, home assistant is up, If I have two or more sensors in file,
home assistant is down.
Please do you help me how I have to write sensors to configuration file and home assistant will up?
Your first sensor should look like this:
  whatever options or settings
Your next sensor needs to look like this:
sensor 2:
When numbering any device, sensor, camera, etc. the first instance is the name, the next instance is name 2:, then name 3: and so on.
I tried what you write to me.
My file if home assistant is up:
homeassistant:
  # Nazov pre domacu atomatizaciu
  #Typ jednotky pre zobrazovanie teploty
  temperature_unit: C
  # Casova zona
  time_zone: Europe/Bratislava
# Enables support for tracking state changes over time.
history:
# Track the sun
sun:
#Udaje o CPU
  platform: cpuspeed
# Discover some devices automatically
discovery:
# Enables the frontend
frontend:
# Allows you to issue voice commands from the frontend
conversation:
# Checks for available updates
updater:
# View all events in a logbook
logbook:
And my file if home assistatn si down:
homeassistant:
  # Typ jednotky pre zobrazovanie teploty
  temperature_unit: C
  # Casova zona
history:
# Track the sun
sun:
#Udaje o CPU
  platform: cpuspeed
sensor 2:
  platform: speedtest
  monitored_conditions:
    - ping
    - download
    - upload
discovery:
frontend:
conversation:
updater:
logbook:
Where can I get errors in the file?
What errors are you getting?
