its called rental control and you can find it here:
Iirc, it can be configured to have one or more caldev calendars which is usually used for when you rent out rooms, but I guess could also be used for this purpose.
I stumbled a little bit with the calendar URL… than a found in the documentation of my provider. I have to add “?ical=true” at the end of my Calender URL, and than it works!
btw, mailbox_org is based on OX App Suite so i think all OX App Suite based apps works as described
oh well…
While the official caldav integration runs very smoothly, but only with one single calendar, the tybritten/ical-sensor-homeassistant seems very buggy.
recurring events are not displayed correctly and a few other things. Hopefully the project will continue to be maintained (which it currently doesn’t look like)
I am aware that this is an old post, but since it was on my top results on my Google search for the same question and I found a solution for it, I think it is worth posting it here for the next people searching for the same thing.
With the default CalDav integration you can indeed import Calendars from multiple Users. Even if the source Calendars have the same name. I wanted to show the NextCloud Calendars of me and my wife in a Dashboard and this is how my configuration looks like:
Usually when you add 2 CalDav entries, HA pulls the first one and when it pulls the 2nd one and the Calendar has the same name, the previously imported entries just get overwritten.
What I did above was utilizing the custom_calendars Tag to basically rename the Calendars on import.
Both our default Calendars in our NextCloud instance are named “Personal”. But with the added tag, I just rename both of them to something else, which then makes it possible to have all 3 of our Calendars (2x Personal renamed + the Holiday Calendar) in our HA instance and we can use them separately or together in our Dashboards
