Can I somehow have 2 e.g. Sonoff ZbBridges in my HA working? Only one integration allowed
Problem is that ZHA devices are in two separate houses on same LAN network but distance is too big for Zigbee… Also no place to install Zigbee repeater.
Best, JR
Hi, unfortunately you can’t do this, it would be like trying to install two routers on your home network i.e. they would conflict.
One way around this would be to move the Sonoff Zigbee Bridge with ZHA to the remote house because this connects with Home Assistant over WiFi. You could then install a Sonoff Pre-flashed CC2531 USB Stick into your Home Assistant hardware and run this with Zigbee2MQTT. I have done this and can confirm that it works.
Thanks for a prompt reply
Will try to install an mesh extender SF-BASIC ZBR3 in the middle then… maybe it covers the distance.
Best, JR
Is it possible to use 2 coordinators with 2 different integrations?
For example, the Sonoff using ZHA and then another (e.g. ConBee II) using deCONZ Addon or Phoscon integration?
Yes it is (if you use zigbee2mqtt even with the same integration, but not when you use the add-on). However, you do create 2 separate Zigbee mesh, the Zigbee devices linked to one coordinator won’t work as a repeater for the zigbee devices linked to the second coordinator.
Makes sense.
I’m actually considering the separate networks intentionally, as I’ve seen reports of Sylvania lights having limited buffer sizes, resulting in dropped transactions on large or very busy networks. As an experiment to see if I get improved reliability, I was thinking to split my 80+ device network into two with separate coordinators. Good to know it should be possible. My second ConBee II got lost by USPS this week, so now I have to wait for a second one to ship
not an expert. but you could flash both sonoff bridges with tasmota (mqtt) option and create separate networks.
They report to HA via mqtt. not ZHA
Hi All,
Looks like this is the right place to ask my question…
I have a Pi4 with a zzh stick and zigbee2mqtt. I have have a Smartthings hub using the ST integration so I see all devices connected to both. The reason for that was that the battery devices were dropping off regularly when a powered device would be switched off and that turned out to be the route. So I left all powered devices (lights, etc.) on the zzh stick and all battery devices on the ST hub. So far all is OK but I am having to make some weird choices in terms of hardware based on whether they would go on the zzh stick or the ST hub.
My question is - is it possible to run zigbee2mqtt on another device, just standalone, and connect to the same mqtt broker of the Pi4? Essentially I want to achieve the same setup as with the ST hub, i.e. to have separate networks for battery and powered devices, but without the ST hub, i.e. avoid the cloud as I see a slight but annoying delay from triggering the sensor to the light coming on.
Or is there another way to run battery and powered devices on a single zigbee stick and not use proprietary hubs?
