Most restarts fail (frozen) with the only feedback of a standard notification:
Starting [xyz integration], not everything will be available until it is finished
Once frozen, attempts at command line:
ha core restart
results in:
Error: Another job is running for job group home_assistant_core
It would be helpful if the logs or a dedicated ‘Startup’ log contained detailed step-by-step of actions it is taking so the last action (causing failure) could be observed.
It would also be helpful if those steps could be observed from notifications on screen during startup so it becomes obvious that the startup has either failed or is just taking a really long time.
An alternative to a startup log file is to allow logger to output user-defined logging to separate files.
It did not complete startup. This was during an attempt to re-install everything and after 7 Add-ons and only 2 Integrations (I restarted after each Add-on and Integration install). The last thing installed was ESPHome which had been running fine since originally installed over 6 months ago and no changes.
Yes, started ok as a bare installation. I added the SSH/Terminal, Samba, and DuckDNS Add-ons and saved that in a VM as my template so I didn’t have to install these every time. As I can add more, I will do the same since this is taking many days to find the problem.
Integrations added were Google Nest and ESPHome from the Integrations page (not from HACS).
Not sure your question “Did you need something specific outside ha”. I haven’t gotten to any of the integrations I need from HACS yet. Just trying to get my basic installation back first.
Running on a Windows 10 machine. VirtualBox (Windows - Home Assistant). This installation has been running well for over 6 months with maybe 15 different HA integrations, plus several HACS integrations.
I’m just starting over with installation because I can’t get my backup to work and don’t know what is causing it.
As you are finding and my original post was that feedback like “recorder started, but didn’t finish” is not helping to isolate the problem.
Also, I just reinstalled again with the same configuration as the log file you now have and it is working fine now, including restarts. Go figure…
It would be nice to have better feedback (like progress, errors, etc) notification and logging during the startup process and options to restart with selective Add-on’s and integrations. Would also be nice to ‘kill’ from the GUI and restart with these options.
