I am a noob so I need help.
I have installed the Mosquitto add-on in Hassio.
The add-on log states the following:
1536698548: New connection from 172.30.32.1 on port 1883.
1536698548: New client connected from 172.30.32.1 as e9c6cdd4-d2e7-4859-b63e-f5dc7a66d154 (xx, xxx, u'xxxxxxx').
The information within parentheses corresponds to the setup in the Owntracks app (iOS).
The status in the app however is:
idle The operation couldn't be completed. Connection refused { “_kCFStreamErrorCodeKey” = 61; “_kCFStreamErrorDomainKey” = 1; }
I do not know how to interpret this.
I have opened the port 8883.
I have the following config for the add-on:
"plain": true,
"plain_websockets": false,
"ssl": false,
"ssl_websockets": false,
"anonymous": true,
"logins": [
"username": "xxxxxxxx",
"password": "xxxxxxxx"
"customize": {
"active": false,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
I have the following in my configuration.yaml
mqtt:
broker: core-mosquitto
username: !secret mqtt_user
password: !secret mqtt_password
I have set up a duckdns account and it works as I can connect to Home Assistant remotely.
In the iOS app I have the following:
Mode: MQTT (there are only the options MQTT and HTTP)
Tracker: an invented name
DeviceID: an invented name
Host: my duckdns adress
Port: 8883
Websockets: off
Proto: 4
TLS: off
Authentication: on
UserID: an invented name
Password: xxxxxxxx
Secret encryption key: empty
Where do I go from here?
I have installed hassio on as Raspberry 3B+ using the method suggested under //Installing Hass.io.
Thx for any help
