Hello I’m new here. First I startet HA on RPI3 then I changed to Fujitsu ESPRIMO Q920. It works fine. But with Mosquitto I have problems.
I want to read a Tasmota device. Because I had some problems, I restored a Backup. I cleared all old entities. Than I want to install the AddOn. The Log looks fine
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[14:13:58] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[14:13:58] INFO: Starting NGINX for authentication handling...
[14:13:59] INFO: Starting mosquitto MQTT broker...
2023-02-11 14:13:59: Warning: Mosquitto should not be run as root/administrator.
[14:13:59] INFO: Successfully send discovery information to Home Assistant.
[14:13:59] INFO: Successfully send service information to the Supervisor.
Than I want to start Mosquitto, but nothing happens. The status of Mosquitto is still “AddOn ist stopped”! Also the Integration says first “No communication”. Some times later I can config the Integration but the AddOn is stopped.
I didn’t know is it only a problem of the status. But I tryed all on different Laptops and browser.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.2.3",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.7",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Berlin",
"os_name": "Linux",
"os_version": "5.15.90",
"supervisor": "2023.01.1",
"host_os": "Home Assistant OS 9.5",
"docker_version": "20.10.22",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"hacs": {
"version": "1.30.1",
"requirements": [
"aiogithubapi>=22.10.1"
"tapo": {
"version": "1.5.1",
"requirements": [
"plugp100==2.5.1"
"integration_manifest": {
"domain": "mqtt",
"name": "MQTT",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/mqtt",
"requirements": [
"paho-mqtt==1.6.1"
"dependencies": [
"file_upload",
"http"
"codeowners": [
"@emontnemery",
"@jbouwh"
"iot_class": "local_push",
"quality_scale": "gold",
"is_built_in": true
"data": {
"connected": true,
"mqtt_config": {
"birth_message": {
"topic": "homeassistant/status",
"payload": "online",
"qos": 0,
"retain": false
"discovery": true,
"discovery_prefix": "homeassistant",
"port": 1883,
"protocol": "3.1.1",
"tls_version": "auto",
"transport": "tcp",
"will_message": {
"payload": "offline",
"qos": 0,
"retain": false
"keepalive": 60,
"broker": "core-mosquitto",
"username": "**REDACTED**",
"password": "**REDACTED**",
"ws_path": "/",
"ws_headers": {}
"devices": [],
"mqtt_debug_info": {
"entities": [],
"triggers": []
I hope, somebody can help.
