I have forwared the port in my router. In the configuration.yaml i have
mqtt:
broker: 192.168.0.71
and
device_tracker:
- platform: owntracks
I have used the app on my Iphone and this works fine now. However I am concerned about the security of this setup. I suppose I could use TLS but not sure how to do with the certificate. Or are there any security concerns regarding having this port opened. I do use duck dns but this is to my router as I have other devices published on the outside.
When in doubt always use security. In fact, Always use security always. Unless you control the channel completely with zero chance of eavesdrop, always use security.
Ok, Point taken. Not really sure how to do this but I suppose I will need the certificate from within hass.io to install on my phone. Where is that located. I also suppose I will need to edit the config file of the broker as shown in the manual. Maybe someone can share the config? As I use a login now I also suppose potentually hackers only could read and not write. Another option would be to use a free public broker.
Another issue I have is that the icons of the phone shows up as a duplicate in HA. My phone is shown 5 times as both home and away. Maybe I missed something here.
