Mosquitto Broker broke
I’ve been running Mosquitto Broke on a HA Blue for quite a while, when Friday it broke.
I did update the Supervisor and HA Thursday or Friday, and am installing the backup from before then, but I want to figure out what broke.
It starts to run then can’t open Port 1884 for listening.
Error: Unable to create websockets listener on port 1884
Has anyone else seen this?
Rob
See this link MQTT broker Unable to create websockets listener on port 1884 for more info.
downgraded os to resolve problem:
ha os update --version 9.5
MQTT usually uses port 1883 - install https://mqtt-explorer.com/ on a client machine and test the broker (mosquitto_sub works also well in the Linux command line).
EDIT: Hmm, interesting GitHub issues chain - issue in libwebsockets or port mapping outside of a container?
My Yellow updated without any issues, so being paranoid, I’d suggest a full backup (copy to another device) and watch for any other errors just in case of a disk starting to go bad.
Otherwise, can I suggest a walk-though of all MQTT settings as a check?:
If this helps, :heart: this post!
thanks. that is what I thought and was looking for and didn’t find
Rob
libwebsockets are updated in today’s new version of Mosquitto
thanks!
I hope they will fix the issue soon
I was challenged with this too today: upgraded to HAOS 10.2 which still has issue.
It took some time/searches to bump on this thread so went back to v9.5.
