I installed Mosquitto broker 5.1 via Home Assistant. I have made no changes to the standard setup. If I run this command from my computer
mosquitto_sub -d -t hello/world -h hassio.local -p 1883
I get:
Client mosq-mz3NTctQDCUHWS245x sending CONNECT
Client mosq-mz3NTctQDCUHWS245x received CONNACK (5)
Connection error: Connection Refused: not authorised.
Client mosq-mz3NTctQDCUHWS245x sending DISCONNECT
I have installed Mosquitto before on other setups and had not problems. I don’t know what is causing this problem. Is there something I need to set up, or otherwise?
