Mosquitto broker integration
Hello folks,
I’m using Mosquitto broker (latest ver) on my Home Assistant (latest ver) and I’ve seen that for some time Mosquitto has a dedicated integration in the UI. Could I remove my YAML configuration safely from my configuration file?
Thank you!
Do you use the Mosquitto Broker add-on? There’s always two parts for HA and MQTT, one is the broker and one is the MQTT integration to tell HA how to communicate with the broker. I assume the YAML config you have is for the integration, if so you can remove it and re-add it through the UI.
