I have had to restore version 4.0 every single time I’ve tried to update the Mosquitto broker add-on.
I am at a loss why it doesn’t work. I’ve googled and tried to find the problem, but I can’t figure it out.
I have no security settings, I have the most standard, plain vanilla installation of the add-on.
Is there something obvious that I am missing? The 4.0 works flawlessly every time I reset it.
Follow the docs and add a the user to the accesscontrollist - so far you only have the permissions but no user. You may also need to add the user homeassistant as well.
I was under the impression that there is no need for a regular user. I am not using any user credentials so far and have all setup under anonymous. Does that not work? The docs make no mention of the setup with anonymous users.
