I am configuring mosquitto to work bridged with AWS IoT.
I have been following the instructions here: https://aws.amazon.com/blogs/iot/how-to-bridge-mosquitto-mqtt-broker-to-aws-iot/
and my mosquitto configuration file is:
# AWS IoT endpoint, use AWS CLI 'aws iot describe-endpoint'
connection awsiot
address a39y4mn9rhffcq-ats.iot.ap-southeast-2.amazonaws.com:8883
# Specifying which topics are bridged
topic garage/door both 1
# Setting protocol version explicitly
bridge_protocol_version mqttv311
bridge_insecure false
# Bridge connection name and MQTT client Id,
# enabling the connection automatically when the broker starts.
cleansession true
clientid bridgeawsiot
start_type automatic
notifications false
log_type all
# Certificate based SSL/TLS support
#Path to the rootCA
bridge_cafile /etc/mosquitto/certs/AmzonRootCA1.pem
# Path to the PEM encoded client certificate
bridge_certfile /etc/mosquitto/certs/4745e52bf9-certificate.pem.crt
# Path to the PEM encoded client private key
bridge_keyfile /etc/mosquitto/certs/4745e52bf9-private.pem.key
The error I am getting is: “1555847480: Error: Unable to load CA certificates, check bridge_cafile “/etc/mosquitto/certs/AmzonRootCA1.pem”.”
Clearly I am not doing the right thing with the certs I am uploading through “configurator”.
Can anyone please advise where I am going wrong?
Thanks!
