I think i found it. i had multiple warning in my log with
Unable to connect to the MQTT broker: Connection Refused: not authorised
As a last resourse ik rebuild the complete mqtt container, and when i was add the part off making the user (passwordfile) i got the following warning.
Warning: File /mosquitto/config/mqttuser has world readable permissions. Future versions will refuse to load this file.
Warning: File /mosquitto/config/mqttuser owner is not root. Future versions will refuse to load this file.Warning
After changing the permission off the file it worked again. I think also that i would have worked in with the ‘old’ container.
I had the same issue. For me it seemed to be that my persistence database was corrupted or something. I moved/deleted data/mosquitto.db and then the container finally started up.
I also deinstalled Mosquitto and reinstalled it. MQTT didn’t need any reconfiguration - a simple reboot and all was well with nothing missing, as far as I could tell.
