I was preparing to setup remote access for my Home Assistant instance. As such I wanted to make sure all my accounts had strong passwords. So I changed the password on the account I was using for MQTT access. After doing so and updating my devices with the new password, none of my devices could connect to the broker anymore . Further testing showed that creating a new HA user worked fine for MQTT access. I thought this was strange so I dug deeper, here is what I found.
Changing the password in HA for a user breaks its ability to be used with Mosquitto.
Deleting the user and creating a new one with the same name does not work. It seems like Mosquitto keeps a list of users that is separate from the HA users. I am aware I can create users in the Mosquitto configuration page that will only work with Mosquitto, but it does say I can just use the HA users instead and most reading I have done seems to imply the HA users are the preferred method. On my setup, I never created any users in the Mosquitto configuration page.
Its almost like Mosquitto watches for HA users, grabs their details and puts it in some difficult to access (aka not part of the config page) file, but does not respect when user accounts change their passwords or get deleted/recreated. So the accounts become unusable for MQTT if the password changes or the account gets deleted and then later recreated.
I did the following:
created a test user
used MQTT Spy to connect to Mosquitto with its credentials to verify it was working
deleted the test user
reconnected using Spy with the credentials of the deleted user and it still worked. this might have
been just a timing thing, possibly if I waited a while Mosquitto would have saw the user was
deleted and denied the connection
restarted HA
attempted to reconnected using Spy with the credentials of the deleted user and it failed
recreated the deleted user with the same username and password
attempted to reconnected using Spy with the credentials of the deleted/recreated user and it failed
restarted HA, tried again, failed, rebooted HA tried again, failed.
I also did basically the same as the above but with a different fresh test user and instead of deleting the user, all i did was changed the users password and had the same results.
I am guessing that uninstalling/re-installing Mosquitto will solve this issue, and thatās not a big deal to do, but Iām guessing that if I knew where the Mosquitto files were stored I would probably find a file someplace with these orphan/ghost user entries and could delete them.
Or maybe I am just entirely off base and there is a specific way I should be changing the passwords when I want them to work with Mosquitto lol.
Let me know your thoughts!
