I am running HomeAssistant in Docker and Mosquitto for mqtt. It is working fine.
Recently, I added Portainer to my docker environment. As I created my containers with compose.yaml, Portainer does not have full access to those containers.
Most of my containers, I can remove and add the them via portainer “Stacks”.
Mosquitto has a conf-file. How do I add this to portainer (Community Edition 2.16.2 - stand alone)?
Mosquitto compose.yaml
# version: as of January 2023, https://docs.docker.com/compose/compose-file/
services:
mosquitto:
image: eclipse-mosquitto:openssl
container_name: mosquitto
networks:
ipvlan70:
ipv4_address: 192.168.70.4
volumes:
- /home/uadmin/Docker/mosquitto/config:/mosquitto/config
- /home/uadmin/Docker/mosquitto/data:/mosquitto/data
- /home/uadmin/Docker/mosquitto/log:/mosquitto/log
restart: unless-stopped
# mosquitto port specifications: https://test.mosquitto.org/ bzw. https://de.wikipedia.org/wiki/MQTT
ports:
- target: 1883
host_ip: 0.0.0.0
published: 1883
mode: host
# Volumes for persisting data
volumes:
config:
driver: local
driver: local
log:
driver: local
# Network specifications
networks:
ipvlan70:
external: true
Mosquitto mosquitto.conf
# mosquitto.conf (see man mosquitto.conf(5) https://mosquitto.org/man/mosquitto-conf-5.html
# GENERAL SETTINGS
# Allow for future listeners not related to main one
# per_listener_settings true
# PROTOCOL / TROUGHPUT / PERFORMANCE
# How much memmory we will allocate (MAX)
# 128MB = 134217728 byte
# 256MB = 268435456 byte
memory_limit 268435456
# mqtt v5 max keepalive
max_keepalive 7200
# mqtt v5 max packet
max_packet_size 65535
message_size_limit 65535
# Expire persistent clients that have not appeared for so much time
persistent_client_expiration 3d
# PERSISTENCE
# Should we even save
persistence true
# Where we save stuff
persistence_location /mosquitto/data
# Treat next settings as number of changes (if true) or seconds otherwise
autosave_on_changes true
# How often to save DB
autosave_interval 600
# LOGGING
# Set the format of the log timestamp.
log_timestamp_format %Y-%m-%dT%H:%M:%S
# What to log
log_type error
log_type warning
log_type notice
log_type information
# do not log to file ... we are in docker
log_dest file /mosquitto/log/mosquitto.log
# and stdout
#log_dest stdout
# LISTENERS
# Listen for incoming network connection on the specified port.
listener 1883
# Password File
# Set the path to a password file
password_file /mosquitto/config/pwfile
#allow_anonymous true
EDIT: the current container has this within:
