I’m trying to troubleshoot why my LED lights are not working after I starting from scratch. I think it might be a MQTT issue even though my client is successfully connecting. In the instructions for Mosquitto, it says the following
- Install the Mosquitto add-on with the default configuration via ‘Hass.io > ADD-ON STORE’. (Don’t forget to start the add-on & verify that ‘Start on boot’ is enabled.)
- Create a new user for MQTT via the
Configuration > Users (manage users)
. (Note: This name cannot be “homeassistant” or “addon”) - Once back on-line, return to
Configuration > Integrations
and select configure next toMQTT
however, when I go to Integrations and click on MQTT: Mosquitto Broker, there is no nothing to configure. The page is blank.
