Mosquitto integration on home assistant portable
hi everyone , i am new in the forum. please advise me how to add mosquitto into home assistant portable.
thanks.
Stop now.
That is an abomination of an install method and will give you nothing but pain.
Use one of the official install methods listed in the docs.
There is no such official installation method.
Where does it come from?
If it is GitHub - AlexxIT/HassWP: Portable version of Home Assistant for Windows (no need to install), see
so you’d have to install mosquitto somewhere yourself.
Thanks appreciate it
Thanks for your help
Thanks once again. How about installing it with pi3 install?
Is it official? On windows pc.
Is home assistant installation pip3
ok ?
See the documentation regarding the supported ways of insralling HA on Windows
And then seriously consider not installing on Windows.
VM should be ok, at least for a “playground” HA. Definitely not something to recommend to a “production” HA, though.
WSL is surely a recipe for frustration unless you really know what you’re doing (don’t expect many user to be able to assist you).
Bottom-line: Invest the $60 for a RPI4 / proper sdcard / proper power supply and install HAOS if / when you want to actually do something else than playing with HA.
Thanks. Very well explained.
Thanks, it will be the raspberry.
