Mosquitto MQTT 4.1 doesnt work after update
Is it possible to have multible
acl_file
set? So we can make a options anon_write or so that set a default ACL like this
Hi I do not understand well how this file accesscontrollist has to be. Currently I have no user (user “” and password “”), how shall I do in my case? Also I have too many topic , do not want to put topic restriction
user ""
When I revert I do get version 4 with old config setup but I cant start it. Do you check home assistant as well in snapshot? When it tries to get the container it says there is no version 4. I run on a pi.
mines working fine?
my mqtt config is:
  "logins": [
      "username": "hidden",
      "password": "hidden"
  "anonymous": true,
  "customize": {
    "active": false,
    "folder": "mosquitto"
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem"
and in the hass config i have:
###MQTT Server
broker: 192.168.0.53
password: !secret mqqt_password
discovery: true
discovery_prefix: homeassistant
4.1 does not work for me either, with or without the mqtt: in configuration.
I had to revert back to 4.0
user mqtt
topic readwrite #
this allows user mqtt to readwrite all topics
How to allow ALL users to readwrite ALL topics?
just topic readwrite # solved it for me
This worked for me as well.
Now running latest HA version and latest Mosquitto addon version.
Sorry for the dumb question. Where should I have to write this?
Does not work for me :disappointed:
/bin/auth_srv.sh: line 15: echo: write error: Broken pipe 1552400547: |-- http req fail url=http://127.0.0.1:8080/login re=Timeout was reached 1552400547: |-- url=http://127.0.0.1:8080/login 1552400547: |-- data=username=hidden&password=hidden&topic=&acc=-1&clientid=
I don’t have any users set. “anonymous” is set to “true” in my case and it works.
@euon
  1. Make sure your mosquitto config has
    “customize”: {
    “active”: true,
  2. Create “mosquitto” folder in /share
  3. Create two files there: acl.conf and accesscontrollist
  4. In acl.conf add line
    acl_file /share/mosquitto/accesscontrollist
  5. In accesscontrollist add line
    topic readwrite #
Thanks for your fast answer.
Now it says that it ca not open the files:
Error: Unable to open include_dir '/share/mosquitto'.
Error found at /etc/mosquitto.conf:27.
Error: Unable to open configuration file.
I have just createt two new textfiles in the new ordner (has it to be a special type?)
Edit: I have researched and I found out that I have no acces to the Share folder over samba. How can I get access to the folder?
I have users, but also if i remove all of them it doesn’t work.
this is the conf:
“logins”: [],
“anonymous”: true,
“customize”: {
“active”: true,
“folder”: “mosquitto”
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
also have acl.conf and accesscontrollist files
I had the same issue since yesterday upgrade to MQTT ver 4.1.
I solved by creating the ACL files as per indication from [xmegapixelx]…but after spending few hours on debugging the issue, including disassembly of my custom ESP8266 relay board which controls my outdoor lights and provide remote temperature - because I suspected a hardware failure of the temp/humidity sensor :-)))
It works now with Mosquitto broker 4.1 version but I disabled the auto-update!
Thank you, guys!
I used the Cloud9 IDE add-on (which offers access to the share folder) to create the missing file structure.
Thanks!!!
It worked!!
Dear all,
this is my working setup:
1- create a user Home Assistant and define a password;
2- configure add.on with the user & password with anonymous off and active as true:
“logins”: [
“username”: “my user”,
“password”: “my password”
“anonymous”: false,
“customize”: {
“active”: true,
3- Create “mosquitto” folder in /share
4- Create two files there: acl.conf and accesscontrollist
5- In acl.conf add line
6- acl_file /share/mosquitto/accesscontrollist
7- In accesscontrollist add this 2 lines:
user my user
topic readwrite #
Log output:
1552422490: New client connected from 10.0.0.157 as sensore07 (c1, k10, u’my user’).
1552422490: |-- mosquitto_auth_unpwd_check(my user)
1552422490: |-- ** checking backend http
1552422490: |-- url=http://127.0.0.1:8080/login
1552422490: |-- data=username=my user&password=user password&topic=&acc=-1&clientid=[INFO] found on local database
1552422492: |-- getuser(my user) AUTHENTICATED=1 by http
I did exactly that and I can’t get it to work. I’ve gone back to active false and it works perfectly. Setup files exactly like you show.
Here’s my setup which worked before and after the update:
  "logins": [],
  "anonymous": false,
  "customize": {
    "active": false,
I create a new home assistant user and password. Those credentials are are what my mqtt clients use to authenticate to the broker.
There is no mqtt: config. I went to configuration > integrations and the broker was discovered by HA. I checked the box for mqtt discovery and hit submit.
I don’t touch any ACL files.
Everything works.
