Mosquitto MQTT Docker image
Hi all,
I use Mosquitto MQTT broker in my Home Assistant setup as it gives me more control than the internal broker.
The image is set up for TLS on a WAN port and with two further ports for LAN and LOCAL, it’s a work in progress but I just published it to Github and thought I’d share in case it was of use to anyone.
My plans next are to add a script to make user creation cleaner (and handle the restart that is currently required so that won’t be needed any more), I also plan to add a random user generator that will output the credentials to the terminal for you.
Hope someone finds it useful.
Great work!! Will be great if you can add the instructions on how to configure it with HA either here or in the readme.
Great idea, hadn’t considered that.
