Hello everyone ,
I have an issue connecting Home Assistant to a TLS enabled Mosquitto MQTT server.
I am using linuxserver/homeassistant and eclipse-mosquitto docker containers.
On the MQTT server I have:
- Configured the broker to use TLS security [ref]
- Added a user in
password_file
[ref] - Tested the setup using MQTT.fx 1.7.1 (properly connects using TLS usind the above created .ca certificate file)
On the Home-Assistant server I have:
- Added the certificate path to configuration.yaml [ref]
The MQTT server is discovered and I am configuring the integration but the connection fails.
The MQTT container log:
1650914314: New connection from 10.0.3.1:41787 on port 8883.
1650914314: OpenSSL Error[0]: error:1404A3F2:SSL routines:ST_ACCEPT:sslv3 alert unexpected message
1650914314: Client <unknown> disconnected: Protocol error.
1650914317: Client connection from 10.0.3.1 failed: error:02FFF020:system library:func(4095):Broken pipe.
