Mosquitto MQTT / Paho: Client connects to broker, but immediately disconnects
Setup:
Hassio running in a docker container on a laptop
Mosquitto MQTT broker add-in
Raspberry Pi in shed connected to DHT22 (temp/humidity sensor) by GPIO.
Paho MQTT client
My mqttlogger is using the following code
# Type of sensor, can be Adafruit_DHT.DHT11, Adafruit_DHT.DHT22, or Adafruit_DHT.AM2302.
DHT_TYPE = Adafruit_DHT.DHT22
# Example of sensor connected to Raspberry Pi pin 4
DHT_PIN  = 4
# Example of sensor connected to Beaglebone Black pin P8_11
#DHT_PIN  = 'P8_11'
if (len(sys.argv) < 2):
   raise  ValueError('Input arguments of mqtt channel temperature humidity not passed')
MOSQUITTO_HOST = '192.168.0.150'
MOSQUITTO_PORT = 1883
MOSQUITTO_TEMP_MSG = str(sys.argv[1]) # Old channel name in here
MOSQUITTO_HUMI_MSG = str(sys.argv[2]) # Old channel name now passed by argument
print('Mosquitto Temp MSG {0}'.format(MOSQUITTO_TEMP_MSG))
print('Mosquitto Humidity MSG {0}'.format(MOSQUITTO_HUMI_MSG))
# How long to wait (in seconds) between measurements.
print "Args length: " + str(len(sys.argv))
FREQUENCY_SECONDS      = 30
if (len(sys.argv) > 4):
        FREQUENCY_SECONDS = float(sys.argv[4])
print('Logging sensor measurements to {0} every {1} seconds.'.format('MQTT', FREQUENCY_SECONDS))
print('Press Ctrl-C to quit.')
print('Connecting to MQTT on {0}'.format(MOSQUITTO_HOST))
mqttc = mqtt.Client("python_pub")
try:
    while True:
        # Attempt to get sensor reading.
        humidity, temp = Adafruit_DHT.read(DHT_TYPE, DHT_PIN)
        # Skip to the next reading if a valid measurement couldn't be taken.
        # This might happen if the CPU is under a lot of load and the sensor
        # can't be reliably read (timing is critical to read the sensor).
        if humidity is None or temp is None:
           time.sleep(2)
           continue
 currentdate = time.strftime('%Y-%m-%d %H:%M:%S')
        print('Date Time:   {0}'.format(currentdate))
        print('Temperature: {0:0.2f} C'.format(temp))
        print('Humidity:    {0:0.2f} %'.format(humidity))
        # Publish to the MQTT channel
        try:
            mqttc.connect(MOSQUITTO_HOST,MOSQUITTO_PORT);
            print 'Updating {0}'.format(MOSQUITTO_TEMP_MSG)
            (result1,mid) = mqttc.publish(MOSQUITTO_TEMP_MSG,temp)
            print 'Updating {0}'.format(MOSQUITTO_HUMI_MSG)
            time.sleep(1)
            (result2,mid) = mqttc.publish(MOSQUITTO_HUMI_MSG,humidity)
            print 'MQTT Updated result {0} and {1}'.format(result1,result2)
            if result1 == 1 or result2 == 1:
                raise ValueError('Result for one message was not 0')
            mqttc.disconnect()
        except Exception,e:
            # Error appending data, most likely because credentials are stale.
            # Null out the worksheet so a login is performed at the top of the loop.
            mqttc.disconnect()
            print('Append error, logging in again: ' + str(e))
            continue
Now it seems to connect to the broker on hassio and says it publishes the values - but I see nothing in integrations, or unused devices. When I look at the log file from the addin, it looks like it connects and then immediately disconnects with a socket error.
1571418576: New client connected from 192.168.0.35 as python_pub (p2, c1, k60).
1571418577: Socket error on client python_pub, disconnecting.
1571418608: New connection from 192.168.0.35 on port 1883.
1571418608: New client connected from 192.168.0.35 as python_pub (p2, c1, k60).
1571418609: Socket error on client python_pub, disconnecting.
This is a long shot as it’s an old post but I am wondering if you found a solution to this problem @stygarfield I am running into this exact problem and have been banging my head trying to figure it out.
Ran into exactly this myself today–also with DHT-22 on a Pi.
I somehow got mine to work after head-banging, but don’t remember what I did to resolve…but it did have something to do with my publish call. I was able to test this by calling connect and disconnect successfully without error and the MQTT logs showed as such. Also–the above codes does not seem to have any username and password entered, is anonymous login enabled in the MQTT configuration?
The original code has the “connect” call every time in the loop which also might by why it’s getting tripped up, connect, then publish in the loop might be the fix?
Definitely not an expert, just wanted to share my learnings.
Make sure your client id is unique. Mosquito at least allows only one session per client id.
