I just recently got into Home Assistant, and I am having issues working with my MQTT devices. I know that the devices work, as I can connect to them if I run them through my other MQTT broker, but when I try to use Hass.IO, I run into problems. I have done searches, but nothing seems to help.
mosquitto.config {
“logins”: [],
“anonymous”: true,
“customize”: {
“active”: false,
“folder”: “mosquitto”
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
config.yaml:
mqtt:
broker: 10.0.0.163 #username: #password:
light:
- platform: mqtt
command_topic: “/test/room/set”
payload_on: “ON”
payload_off: “OFF”
the light is just a test to see if the MQTT is actually working. I then SSH into it and use the following code to look for the topics: mosquitto_sub -h 10.0.0.163 -t "test/room/#" Howver, I do not see any topics come across. This is my mosquitto.log at the bottom of the page which tells me that my ssh is connected: 1546983494: New client connected from 172.30.32.1 as mosqsub|792-core-ssh (c1, k60).
Is there a log or file, that allows me to see the history of all messages sent?
In a related, but seperate issue, when I try to connect to the hass.io from my computer I get following: 1546983727: New client connected from 10.0.0.69 as mosqpub/1244-Frankie (c1, k60).
1546983727: ACL denying access to client with dangerous client id “mosqpub/1244-Frankie”
1546983727: Client mosqpub/1244-Frankie disconnected.
I understand that it has to do the dash before Frankie, but not sure how to get around it.
I’m Having the same issue in the Mosquitto log where a client is being denied. Googling this issue does not point me in a direction for troubleshooting. From what i can tell Mosquitto is set up correctly but am not certain as this is my first client.
1547244110: ACL denying access to client with dangerous client id “shadePosition/shade_stepper”
Mosquitto is set to the IP of my home assistant because as I understand it Mosquitto runs on HA.
Thank you I have updated the confg with no “/” to “shadePositionshade_stepper” The Mosquitto log file is showing all is good. But no response from my connected device.
[INFO] Setup mosquitto configuration
[INFO] No local user available
[INFO] Initialize Hass.io Add-on services
[INFO] Initialize Home Assistant discovery
[INFO] Start Mosquitto daemon
1547298754: mosquitto version 1.4.15 (build date 2018-03-04 15:35:59+0000) starting
1547298754: Config loaded from /etc/mosquitto.conf.
1547298754: *** auth-plug: startup
1547298754: ** Configured order: http
1547298754: Opening ipv4 listen socket on port 1883.
1547298754: Opening ipv6 listen socket on port 1883.
1547298754: Opening websockets listen socket on port 1884.
1547298754: Opening ipv4 listen socket on port 8883.
1547298754: Opening ipv6 listen socket on port 8883.
1547298754: Opening websockets listen socket on port 8884.
1547298754: Warning: Mosquitto should not be run as root/administrator.
1547298759: New connection from 192.168.0.29 on port 1883.
[INFO] found on Home Assistant
1547298760: New client connected from 192.168.0.29 as shadePositionshade_stepper (c1, k15, u’‘).
1547298793: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1547298793: New client connected from as d2fde68a-b049-4420-b982-14fc4656bd5f (c1, k60, u’homeassistant’).
This project is running the following arduino code on esp8266 where i can see that the device connects to WiFi and then connects successfully to MQTT.
I have not tried running a program that will flash the esp8266. That is probably my next step in troubleshooting since the device is not responding from commands sent from home assistant.
