Mosquitto not working
Hi. I’m running version 0.103.4 and having trouble with Mosquitto broker. I’ve installed Mosquitto addon (5.1), created a user (Mqttuser) and password.
Configuration:
  "logins": [
      "username": "MqttUser",
      "password": "######"
  "anonymous": false,
  "customize": {
    "active": true,
    "folder": "mosquitto"
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "require_certificate": false
I’ve created ACL according to description on the add-on page.
Contents of acl.conf:
acl_file /share/mosquitto/accesscontrollist
Contents of accesscontrollist:
user Mqttuser
topic #
user homeassistant
topic #
When I try to test the MQTT on this page:
I get this error:
Somehow it disconnects from MQTT and (naturally) the test fails. Anybody got any idea what I’ve done wrong?
If you try mqtt.publish, use either payload or payload_template, not both. And for testing, always use retain : false, or your test will stay in the mosquitto db forever.
Thanks, no errors when I remove the payload_template :slight_smile:
