I am running Mosquitto Broker within HA and noticed that it using port 1883 which documentation says is insecure and can be disabled. So I made following changes:
- Disabled port 1883
- changed the configuration setting “require certificate to true”
- In the ssl folders there are two files namely “fullchain.pem” and privkey.pem"
- Restart Mosquitto
Now when I try to connect to MQTT broker on port 1884, 8883 or 8884 - I am not able to connect.
Did I miss something from above steps or did not follow the documentation properly?
Thanks.
