My HA installation’s storage needs have been growing at an impractical rate and I would like to be able to get some perspective on the cause. This should be a relatively simple situation to sort out, but when I start looking into how to troubleshoot this on a HA system it starts looking quite complicated .
Below is the outline of my configuration, can someone suggest a relatively efficient way to tackle a task like this based on my config?
Perhaps the simple tool like Scanner (if you use Windows) or Daisy Disk (for Mac, available from AppStore). Might require Samba add-on and mapping folders to drive letters, but as result you can get nice charts showing details of disc usage and then you can drill down to find where the most of used space goes to. Here is example of my config folder from my instance of HA:
