Hi!
I’m trying to wrap my head around what’s the shortest and most comprehensible way going forward here, perhaps there are some best practices or common ways…?
Problem is simple: I have an entity with a numeric state and want to create an automation that fires only when the state, an integer, increases. The crux here is that the entity can also be unavailable and I want to avoid firing the automation when it goes to or comes back from unavailable
For example, let’s use my sensor.vacuum_total_clean_count
Approach 1
entity_id: sensor.vacuum_total_clean_count
platform: state
This will trigger for all state changes, including 22
→ unavailable
→ 22
Approach 2
platform: state
condition:
- condition: template
value_template: >
{{ trigger.to_state.state | float > trigger.from_state.state | float }}
Since the float filter defaults to 0,0
this will also trigger when going from unavailable
to 22
since the former renders as 0,0
… also if I add some other default values I would have to make up an arbitrary huge number for the “from state float” to avoid triggering on unavailable
→ 22
which feels bad…
Approach 3
platform: state
condition:
value_template: >
{{ trigger.from_state.state is not 'unavailable' and
This is starting to look better but then I’m reading up on templating and I see that I should also cover for undefined values…
Approach 4
platform: state
condition:
value_template: >
{{ trigger.from_state is not none and
trigger.to_state is not none and
Now this is starting to become quite a lot of code that in my opinion reads different from what I’m trying to achieve… so it makes me wonder, is there a more idiomatic approach here? Something else I’m not seeing?
I guess you can throw is_number
into the mix too, but you still have to cover for undefined values then as well right?
And I’ve seen that some entities report the state as unknown
instead of unavailable
… is there some simple way to check for both none
, unknown
and unavailable
(and god knows what else?) or do I need to explicitly check each…?
Thanks in advance for any best practices and help navigating this templating jungle!
