I’ve recently made a motion activated lighting system to illuminate my stairs during the night. The circuit runs on battery power since there is no easy access to the mains where I want to install it.
The circuit has a connector for the LEDs, two PIR sensors and one BH1750 light sensor. Everything is controlled by an ESP32 WROOM 32E.
The ESP should spend most of the time sleeping to conserve battery life and only come on when motion is detected, take a reading from the BH1750 sensor and turn the lights on / go back to sleep depending on what the light level is.
The issue I believe I have is that the I2C connection to the BH1750 takes too long and the check of the BH1750’s state returns nan when waking from deep sleep first. I’ve tried delays up to 1s to allow the sensor to initialize without luck. Is there a solution that would allow the sensor to connect and be read quicker or some other way of implementing this functionality?
Here is my configuration:
esphome:
friendly_name: Treppenlichter Oben
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
ota:
- platform: esphome
password: "***"
wifi:
fast_connect: true
ssid: !secret wifi_ssid
ap:
ssid: "Treppenlichter-Oben"
password: "***"
mqtt:
broker: !secret mqtt_broker
username: mqtt-user
password: !secret mqtt_password
topic_prefix: homeassistant/treppenhaus
i2c:
sda: GPIO21
scl: GPIO22
- platform: bh1750
name: "Treppenlicht Oben Helligkeit"
address: 0x23
update_interval: never
- platform: adc
name: "Treppenlicht Oben Spannung"
pin: GPIO35
attenuation: auto
filters:
- multiply:
1.33
binary_sensor:
- platform: gpio
pin:
number: GPIO2
allow_other_uses: true
publish_initial_state: true
on_press:
- component.update: treppenlicht_oben_helligkeit
- if:
condition:
lambda: |-
return id(treppenlicht_oben_helligkeit).state < 30;
then:
script.execute: script_pir_unten
else:
deep_sleep.enter:
- platform: gpio
pin:
number: GPIO34
on_press:
- if:
condition:
lambda: |-
then:
script.execute: script_pir_oben
else:
deep_sleep.enter:
output:
- platform: ledc
pin: GPIO32
- platform: ledc
pin: GPIO33
- platform: ledc
pin: GPIO25
- platform: ledc
pin: GPIO14
- platform: ledc
pin: GPIO27
- platform: ledc
pin: GPIO26
- platform: ledc
pin: GPIO13
- platform: ledc
pin: GPIO23
- platform: ledc
pin: GPIO19
light:
- platform: monochromatic
output: LED_1_OUTPUT
internal: true
output: LED_2_OUTPUT
internal: true
output: LED_3_OUTPUT
internal: true
output: LED_4_OUTPUT
internal: true
output: LED_5_OUTPUT
internal: true
output: LED_6_OUTPUT
internal: true
output: LED_7_OUTPUT
internal: true
output: LED_8_OUTPUT
internal: true
output: LED_9_OUTPUT
internal: true
deep_sleep:
esp32_ext1_wakeup:
pins:
- number: GPIO2
- number: GPIO34
mode: ANY_HIGH
wakeup_pin_mode: KEEP_AWAKE
script:
- id: script_pir_unten
then:
- delay: 10ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 30s
- light.turn_off: LED_1
- light.turn_off: LED_2
- light.turn_off: LED_3
- light.turn_off: LED_4
- light.turn_off: LED_5
- light.turn_off: LED_6
- light.turn_off: LED_7
- light.turn_off: LED_8
- light.turn_off: LED_9
- delay: 1s
- deep_sleep.enter:
- id: script_pir_oben
then:
- delay: 10ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 100ms
- light.turn_on:
brightness: 25%
- delay: 30s
- delay: 1s
- deep_sleep.enter:
