Hi
I wanted to share my first blueprint which works for me (so far) almost perfectly as intended.
It is based on @networkingcat blueprint, but simplified and adjusted to my day/night behavior and needs.
There are many variants of motion activate lights which required light entity and was either fully dependent on hour or sun position. I wanted to have it more like this:
- Day scene is active from sun azimuth (close to sunrise) till specific hour (when we go sleep).
- Night scene is active from specific hour to sun azimuth .
- Ambient scene is active from sun azimuth in evening till some hour.
- Day/Night scene is active only when light sensor have low LUX value (I’m checking outside light so when it’s cloudy then it makes sense to use scene).
You will need only light sensor and some scenes.
blueprint:
name: YAMA Falo Scenes v2
description: >
# YAMA Falo Scenes
Turn on scenes when motion is detected.
Separate scene for day and night
Assumptions:
1. Day scene is active from sun azimuth (close to sunrise) till specific hour (when we go sleep).
2. Night scene is active from specific hour to sun azimuth .
3. Ambient scene is active from sun azimuth in evening till some hour.
4. Day/Night scene is active only when light sensor have low LUX value (I'm checking outside light so when it's cloudy then it makes sense to use scene).
domain: automation
input:
motion_entity:
description: Motion Sensor or a group with Motion Sensors (But can be anything switching between "on" and "off")
selector:
entity:
domain: binary_sensor
device_class: motion
illuminance_sensor:
name: (OPTIONAL) Illuminance sensor
description: This sensor will be used to determine the illumination.
default:
selector:
entity:
domain: sensor
device_class: illuminance
illuminance_cutoff:
name: (OPTIONAL) Illuminance cutoff value
description: This input_number will be used to compare to the current illumination to determine if it is low.
default:
selector:
number:
min: 0
max: 3600
unit_of_measurement: lux
no_motion_wait:
description: Time to leave the light on after last motion is detected.
default: 120
selector:
number:
min: 0
max: 3600
unit_of_measurement: seconds
scene_day:
name: DAY Scene (Optional)
default: scene.none
selector:
entity:
domain: scene
scene_night:
name: NIGHT Scene (Optional)
default: scene.none
selector:
entity:
domain: scene
time_scene_night_start:
name: NIGHT Scene start - time (Optional)
description: A time input which defines the time from which on the scene will be activated if motion is detectedd.
default: "22:00:00"
selector:
time:
sun_scene_night_end:
name: NIGHT Scene end - sun possition (Optional)
description: Night scene will go off after sun is higher than
default: none
selector:
number:
min: -90
max: 90
unit_of_measurement: degrees
scene_ambient:
name: AMBIENT Scene (Optional)
description: Scene for ambient state. Will be activated when no motion is detected.
default: scene.none
selector:
entity:
domain: scene
sun_scene_ambient_start:
name: AMBIENT scene start - sun (Optional)
description: Time from which on ambient scene will be activated
default: none
selector:
number:
min: -90
max: 90
time_scene_ambient_end:
name: AMBIENT scene end - sun (Optional)
description: Time from which on ambient scene will be not activated
default: "23:30:00"
selector:
time:
scene_dark:
name: DARK Scene (Optional)
description: Scene for DARK STATE state. Will be activated when no motion is detected.
default: scene.none
selector:
entity:
domain: scene
time_day_change:
name: Time when "day" is over
description: This is only needed for conditions to work correctly
default: "03:00:00"
selector:
time:
mode: restart
max_exceeded: silent
variables:
scene_ambient_start: !input sun_scene_ambient_start
scene_night_end: !input sun_scene_night_end
- platform: state
entity_id: !input motion_entity
to: "on"
- platform: state
to: "off"
for: !input no_motion_wait
# All Conditions must be true
#condition:
#No special conditions in this blueprint
- choose:
# Trigger to state == "on"
- conditions:
- condition: template
value_template: "{{ trigger.to_state.state == 'on' }}"
- condition: numeric_state
entity_id: !input "illuminance_sensor"
below: !input "illuminance_cutoff"
sequence:
- choose:
# day Scene
- conditions:
- "{{ scene_day != 'scene.none'}}"
- condition: time
after: !input time_day_change
before: !input time_scene_night_start
sequence:
- scene: !input scene_day
# Night Scene
- conditions:
- "{{ scene_night != 'scene.none'}}"
- condition: time
after: !input time_scene_night_start
before: !input time_day_change
value_template: "{{ (state_attr('sun.sun','elevation') < scene_night_end) }}"
sequence:
- scene: !input scene_night
# Trigger to state = "off"
- conditions:
value_template: "{{ trigger.to_state.state == 'off' }}"
sequence:
- choose:
# Used if ambient scene is true and in ambient scene time frame
- conditions:
- "{{ scene_ambient != 'scene.none' }}"
- condition: time
before: !input time_scene_ambient_end
value_template: "{{ (sun_scene_ambient_start == none) or (state_attr('sun.sun','elevation') <= scene_ambient_start) }}"
sequence:
- scene: !input scene_ambient
default:
- scene: !input scene_dark
