Hello, i was using motion blinds integration successfully for a while now, but had to reconfigure everything when my bridge lost the wifi connection.
I also did a firmware upgrade of the bridge.
I then deleted the old integration and tried to install it from scratch, but i am unable to get it working:
Received actionResult: 'AccessToken error
I checked the access token twice, even installed the app on another phone and tried to retrieve the token from there.
Is this a maybe known bug with the newest firmware of the bridge?
Full log:
Logger: motionblinds.motion_blinds
Source: /usr/local/lib/python3.8/site-packages/motionblinds/motion_blinds.py:368
First occurred: 21:18:51 (4 occurrences)
Last logged: 22:50:49
Received actionResult: 'AccessToken error', when sending message: '{'msgType': 'ReadDevice', 'mac': '8caab5ca918b', 'deviceType': '02000001', 'msgID': '20210517191851610'}'
Received actionResult: 'AccessToken error', when sending message: '{'msgType': 'ReadDevice', 'mac': '8caab5ca918b', 'deviceType': '02000001', 'msgID': '20210517192706570'}'
Received actionResult: 'AccessToken error', when sending message: '{'msgType': 'ReadDevice', 'mac': '8caab5ca918b', 'deviceType': '02000001', 'msgID': '20210517193223390'}'
Received actionResult: 'AccessToken error', when sending message: '{'msgType': 'ReadDevice', 'mac': '8caab5ca918b', 'deviceType': '02000001', 'msgID': '20210517205049081'}'
Yes this was a bug in the firmware of the bridge.
This bug has been fixed in later versions of the bridge and also in later versions of HomeAssistant attempts were made to cercumvent this bug.
Are you still experaincing these errors or any other issues on the latest firmware of the bridge and the latest HomeAssistant version?
I started getting this error after one of the last few updates. Iām currently at 2022.8.1. Reading the blinds entities works but I canāt control them. As suggested by the docs, I have disabled the āwait for multicast push on updateā checkbox but still to no avail. Both bridge and hassio are up-to-date.
I canāt get over the fact the controlling the blinds works from Google Home. Is there anything else I can check to debug this issue?
Update: I also see this error in the logs: āCould not find working interface for Motion Blinds host 192.168.1.222, using interface āanyāā. It sounds like a warning rather than a real error though.
I have deleted/installed the integration several attempts and no luck there
Im not quite following you on the connection of the Motion Blinds gatewayā¦ Also not sure what the hacs access point is, I do use hacs so thatās installed
You can turn your raspi into a WIFI access point, only if the former has a wireless adapter and itās not in use. In my case I connect my raspi via ethernet cable so I use the WIFI AP to:
make sure multicast for motion blinds gateway works which is not guaranteed if you using your wifi router
have static IPs for some tuya devices which is needed for localtuya
The way to get the wifi ap working is Settings ā Addons ā Hass.io Access Point. Hereās an excerpt from my config:
