Motion Blinds and Dooya
Hi
Is it possible to issue the command ‘stop’ in an automation to Dooya Blinds when using the motion blinds integration?
I have two blinds setup and can manually start and stop them from the home assistant dashboard as per the image below
However, when accessing the device in an automation there is only the option of moving them to a set position - i.e. fully open, 50% open, fully closed etc…What I want to be able to do is link them to a button switch that when i press one button they start moving and then press the second buttom for them to stop.
Am i missing something very obvious here?
Thanks!
