Hi All,
I have two Aeotec multisensors in my setup, both of which have no longer have the motion sensor available in home assistant and I have no clue why. Hope someone is able to help.
What I know:
It was working on 0.87.1 last about a week ago for sure. I have since upgraded to 0.88 and back to 0.87.1 but the sensors have not come back.
Other sensors in home assistant, coming frmo the same device (such as temperature and humitidy) are working fine.
No errors in the home assistant log when restarting an zwave is setting up:
2019-02-24 07:17:24 INFO (MainThread) [homeassistant.setup] Setting up zwave
2019-02-24 07:17:24 INFO (MainThread) [homeassistant.setup] Setup of domain zwave took 0.0 seconds.
2019-02-24 07:17:26 INFO (MainThread) [homeassistant.loader] Loaded config.zwave from homeassistant.components.config.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor.zwave from homeassistant.components.binary_sensor.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.loader] Loaded climate.zwave from homeassistant.components.climate.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.components.climate] Setting up climate.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.loader] Loaded cover.zwave from homeassistant.components.cover.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.components.cover] Setting up cover.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.loader] Loaded fan.zwave from homeassistant.components.fan.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.components.fan] Setting up fan.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.loader] Loaded lock.zwave from homeassistant.components.lock.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.components.lock] Setting up lock.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.loader] Loaded switch.zwave from homeassistant.components.switch.zwave
2019-02-24 07:17:27 INFO (MainThread) [homeassistant.components.switch] Setting up switch.zwave
2019-02-24 07:17:28 INFO (MainThread) [homeassistant.loader] Loaded light.zwave from homeassistant.components.light.zwave
2019-02-24 07:17:28 INFO (MainThread) [homeassistant.components.light] Setting up light.zwave
2019-02-24 07:17:32 INFO (MainThread) [homeassistant.loader] Loaded sensor.zwave from homeassistant.components.sensor.zwave
2019-02-24 07:17:32 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.zwave
2019-02-24 07:17:56 INFO (SyncWorker_19) [openzwave] Start Openzwave network.
2019-02-24 07:17:57 INFO (Dummy-18) [openzwave] Driver ready using library Static Controller version Z-Wave 3.95
2019-02-24 07:17:57 INFO (Dummy-18) [openzwave] home_id 0xec00e8e3, controller node id is 1
And when checking the OZWLog (from home assistant), I still see stuff in the log when I trip the motion sensor:
2019-02-24 07:25:25.482 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x04, 0x03, 0x03, 0x30, 0x03, 0xff, 0x3a
2019-02-24 07:25:25.482 Info, Node003, Received SensorBinary report: Sensor:58 State=On
2019-02-24 07:25:25.482 Detail, Node003, Refreshed Value: old value=false, new value=true, type=bool
2019-02-24 07:25:25.482 Detail, Node003, Changes to this value are not verified
2019-02-24 07:25:25.482 Detail, Node003, Notification: ValueChanged
2019-02-24 07:25:25.497 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x30, 0x03, 0xff, 0x3e
2019-02-24 07:25:25.497 Info, Node003, Received SensorBinary report: Sensor:62 State=On
2019-02-24 07:25:25.497 Detail, Node003, Refreshed Value: old value=true, new value=true, type=bool
2019-02-24 07:25:25.497 Detail, Node003, Changes to this value are not verified
2019-02-24 07:25:25.497 Detail, Node003, Notification: ValueChanged
2019-02-24 07:25:25.730 Detail, Node003, Received: 0x01, 0x11, 0x00, 0x04, 0x04, 0x03, 0x0b, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x08, 0x00, 0x00, 0x00, 0x62
2019-02-24 07:25:25.730 Info, Node003, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2019-02-24 07:25:25.730 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2019-02-24 07:25:25.730 Detail, Node003, Changes to this value are not verified
2019-02-24 07:25:25.730 Detail, Node003, Refreshed Value: old value=0, new value=8, type=byte
2019-02-24 07:25:25.730 Detail, Node003, Notification: ValueChanged
2019-02-24 07:25:25.735 Detail, Node003, Notification: ValueChanged
2019-02-24 07:25:25.742 Detail, Node003, Notification: ValueChanged
2019-02-24 07:25:25.747 Detail, Node003, Notification: ValueChanged
2019-02-24 07:25:25.751 Detail, Node003, Received: 0x01, 0x11, 0x00, 0x04, 0x00, 0x03, 0x0b, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x08, 0x00, 0x00, 0x00, 0x66
2019-02-24 07:25:25.751 Info, Node003, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2019-02-24 07:25:25.751 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2019-02-24 07:25:25.751 Detail, Node003, Changes to this value are not verified
2019-02-24 07:25:25.751 Detail, Node003, Refreshed Value: old value=8, new value=8, type=byte
2019-02-24 07:25:25.752 Detail, Node003, Notification: ValueChanged
2019-02-24 07:25:25.756 Detail, Node003, Notification: ValueChanged
2019-02-24 07:25:25.760 Detail, Node003, Notification: ValueChanged
2019-02-24 07:25:25.764 Detail, Node003, Notification: ValueChanged
So, my conclusions so far:
- The hardware is still working fine
- The zwave network is still picking up the sensor and reporting it to the NUC.
- Does not seem related to upgrading home assistant
But, I have no clue how to get those sensors back in home assistant or what may have caused them to be lost in the first place?
Anybody able to chime in?
