In what should be one of the easier automations I do, I’m struggling with some light control via automation, and it’s really killing the WAF:
I have a bayesian sensor in my garage that is comprised of a door sensor and 2 motion sensors. If the door is open or one of the motion sensors has detected motion, the bayesian gets set to on.
I have a flow in NodeRed that turns the light on when the bayesian turns on. This works flawlessly.
I then want the light to turn off after 10 minutes of inactivity. However, what I’m finding is if I’m in the garage moving around for 10+ straight minutes, meaning that the bayesian always stays to on, the light still turns off after 10 minutes. If I leave the garage for a period of time after the light has turned on, meaning that the bayesian tuns off, the timer will reset when I re-enter the garage and all’s good.
Am I missing something here? I’ve used the DIYFuturism example of as the basis for my method, and I think I’ve copied it verbatim.
[{"id":"578f4dc6.638ab4","type":"server-state-changed","z":"91bccc5.005dd3","name":"Garage Motion Detection - Bayesian","server":"20f36b65.1b39b4","version":1,"entityidfilter":"binary_sensor.garage_bayesian_motion_sensor","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"x":180,"y":180,"wires":[["c24c271c.5a5d78"]],"info":"binary_sensor.motion_sensor_158d00036d5a35_garage_workbox"},{"id":"ce96400c.9433c","type":"stoptimer","z":"91bccc5.005dd3","duration":"10","units":"Minute","payloadtype":"num","payloadval":"0","name":"10 minutes til off","x":620,"y":220,"wires":[["f93afcc0.4e406"],[]]},{"id":"f93afcc0.4e406","type":"api-call-service","z":"91bccc5.005dd3","name":"Turn them off","server":"20f36b65.1b39b4","version":1,"service_domain":"homeassistant","service":"turn_off","entityId":"switch.zooz_willis_electric_unknown_type_1e01_id_1e01_switch_ceiling_garage","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":870,"y":220,"wires":[[]]},{"id":"b578a905.f2a398","type":"api-call-service","z":"91bccc5.005dd3","name":"No? Turn them on","server":"20f36b65.1b39b4","version":1,"service_domain":"homeassistant","service":"turn_on","entityId":"switch.zooz_willis_electric_unknown_type_1e01_id_1e01_switch_ceiling_garage","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":950,"y":160,"wires":[[]]},{"id":"c24c271c.5a5d78","type":"switch","z":"91bccc5.005dd3","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":430,"y":180,"wires":[["ce96400c.9433c","cae5077b.d88088"],["ce96400c.9433c"]]},{"id":"cae5077b.d88088","type":"api-current-state","z":"91bccc5.005dd3","name":"Are the lights already on?","server":"20f36b65.1b39b4","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"switch.zooz_willis_electric_unknown_type_1e01_id_1e01_switch_ceiling_garage","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":650,"y":160,"wires":[[],["b578a905.f2a398"]]},{"id":"59482fcf.d25f9","type":"comment","z":"91bccc5.005dd3","name":"Garage Motion Detection","info":"","x":150,"y":140,"wires":[],"icon":"node-red/bluetooth.png"},{"id":"20f36b65.1b39b4","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
