Hi there,
I want to have a first thing in the morning automation, so that wnem I walk downstairs, the kitchen lights turn on and then just stay on.
I have the following automation, but it just triggers constantly when walking around.
Any ideas how I can achieve this? I was thinking that I could have some sort of condition that says ‘if the sensor hasn’t seen motion for a minimum of two hours’ or something?!??
- id: '9'
alias: 'Morning Motion'
- platform: state
entity_id: sensor.hall_motion_sensor
to: 'on'
condition:
condition: and
conditions:
- condition: time
before: '08:30:00'
after: '03:00:00'
- condition: state
entity_id: group.family
state: 'home'
- service: notify.pushbullet
message: 'Good Morning'
target: 'device/Google Pixel 2'
- service: script.good_morning
you could use a condition as you mentioned to restrict it triggering unless it has been ‘off’ for ‘x’ hours,
or,
you could use an input_boolean which is set on the first trigger and then forms part of a condition to prevent the automation triggering again later. You would then reset that input_boolean later, say at midnight via another automation or perhaps a bedtime routine.
I have split my day into 5 different time spans. Every part of the day, consists of a group of automations. E.g. when the time is 05:30:00 on a workday, the “Morning work” automation is triggered. What it does is, that it turns off all light automations, and turns on the ones defined in my “Morning Work Light” automation group. In that way, I can easily add new automations, and keep track of my light automations if something seems odd.
Thanks for the info people!
I have (hopefully) achieved it like this:
- id: 'morning_motion'
- platform: state
to: 'on'
condition:
condition: and
conditions:
- condition: time
before: '08:30:00'
after: '03:00:00'
- condition: state
state: 'home'
- id: 'morning_motion_turn_off'
alias: 'Morning Motion Disable'
- platform: state
to: 'on'
- delay: '00:00:10'
message: 'Morning motion turned off'
- service: automation.turn_off
entity_id: automation.morning_motion
entity_id: automation.morning_motion_turn_off
- id: 'morning_motion_reset'
alias: 'Morning Motion Enable'
- platform: time
at: '02:45:00'
- service: automation.turn_on
actually - it looks like this isn’t working. I can’t get the automation to turn itself off.
I think I may try the sensor to: ‘off’ for 2 hours option.
Aaaaargh!
I’m trying to add a condition for the sensor to be off for 2 hours, but it is throwing up errors.
Can someone take a look. It is definitely the sensor condition that is causing the error (I’m guessing a formatting issue).
- platform: state
to: 'on'
condition:
condition: and
conditions:
- condition: time
before: '09:00:00'
after: '03:00:00'
- condition: state
state: 'home'
- condition: state
to: 'off'
for:
hours: 2
