Good Morning,
I have several motion detectors for turning on the lights in the house automatically for 2 minutes. Is working fine so far, but there is one challange:
Example:
On my staircase, I have two motions sensor, one on the grooundfloor, one on the 1. Level. When the first one in the groundfloor is triggered the two minutes are counted down and the light goes out, no matter what.
But what I want to archive is that the countdown starts again, two minutes, when triggering the light now in the first floor. Assuming there is 30 seconds rest and I’m passing the second motion detector on the first floor, it is supposed to setting the time to two minutes again because otherwise the light goes off while I walk down the stairs which is dangerous at night time.
Any Ideas how I may archive that?
This is how my simple automation looks like, using the blueprint “yet_another_motion_automation” and the parameter “no_motion_wait” - which I want to override when passing the second motion detector for the same light wihtin these two minutes:
Post your full automation and make sure to format it correctly.
Instead of creating your own thread, why didn’t you post in the blueprint topic?
That topic I linked to above clearly states you can use a “no motion blocker” to accomplish what you want, including a flowchart which explains how it works.
Have a read through that thread and try to use the information provided there. If something isn’t clear, posting there will increase your odds of getting an answer which is compatible with that particular blueprint
Have you tried a “wait for trigger” with the other motion detector? You would have to do two automations: One for someone going upstairs and another for someone going downstairs.
I didn’t post it over there because I thought I maybe wrong to post it there.
But I believe I explained it maybe bad due to my english. So this is what I want to archieve:
I want the light to go out, but I want the first motion detector in the Ground Floor to be overwritten by the second motion detector in the Second Floor, so that the 2 Minutes to keep the lights on then counts down from the beginning again. If I goint to set the no_motion_blocker in both motion detectors - the light will never switch off - I’m I right or do I read the workflow in a wrong way?
thanks for the answer - but this means 8 more automations… I try rather to find a way to solve it within the same automation. I’m loosing already track of things with 70 automations.
If that’s the only scenario, you would only set the no motion blocker on the ground floor sensor. The second floor sensor doesn’t need to block anything.
The previous suggestion to use wait for trigger would also work, and no, you wouldn’t need to set up more automations. You’d just edit your existing one or modify the blueprint.
Again, I suggest posting in the blueprint topic since people there will be more familiar with the most efficient way to handle this.
Actually, it shouldn’t matter which motion detector I pass and trigger, the timer always should count from the beginning again (120 Seconds) and deactivate the ones that I triggered, for example, a minute before.
I moved the thread to the “Blueprint Exchange” Section.
In that case, you’ll need to insert a wait_for_trigger with continue_on_timeout: true and a delay of 2 mins, as suggested.
PS- Blueprints Exchange is just what the name implies - it’s used to share blueprints, not to post new topics with individual issues.
Just add it as a reply in the YAMA topic I linked to earlier, since that is specific to your blueprint
That said without looking at your code, if you create an automation that triggers on the first sensor, has a wait-for-trigger #2 and then does your other thing. You have the flowchart in that paragraph already, just do all the things in an automation.
Thanks a lot and also thanks for being patient with me since I have not much experience with this kind of material - never did automations before in yaml files.
therefore, may I kindly ask where I have to put what parameters and what syntax exactly in the yaml file?
blueprint:
name: Yet Another Motion Automation
description: "# YAMA V10\n\nTurn on lights or scenes when motion is detected. \nFour
different scenes can be defined depending on time of day.\n\nFor Details see this
forum post:\nhttps://community.home-assistant.io/t/yama-yet-another-motion-automation-scenes-ambient-light-and-some-conditions/257062?u=networkingcat\n\nCapabilitys:\n\n
- Trigger on motion (in fact can be triggered by anything that switches between
“on” and off\")\n - Wait time for turning off\n - Only run if entity is in desired
state (optional)\n - Sun elevation check (optional)\n - 4 Scenes for different
times of day (optional)\n - Ambient support with time frame (optional)\n - Default
scene when motion stops (optional)\n - “no motion blocker” with user choosable
state (optional)\n"
domain: automation
source_url: https://gist.github.com/networkingcat/a1876d7e706e07c8bdcf974113940fb8
input:
motion_entity:
description: Motion Sensor or a group with Motion Sensors (But can be anything
switching between "on" and "off")
selector:
entity: {}
light_target:
selector:
entity:
- domain:
- light
no_motion_wait:
description: Time to leave the light on after last motion is detected.
default: 120
selector:
number:
min: 0.0
max: 3600.0
unit_of_measurement: seconds
mode: slider
step: 1.0
automation_blocker:
name: Automation Blocker (Optional)
description: Only run if this boolean is in desired state (see next input)
default:
selector:
entity: {}
automation_blocker_boolean:
name: Automation Blocker Chooser (Optional)
description: Desired state of automation blocker, choose on for on and off for
off
default: false
selector:
boolean: {}
no_motion_blocker:
name: No Motion Blocker (Optional)
description: No motion sequence is not run if this boolean is in desired state
(see next input)
default:
selector:
entity: {}
no_motion_blocker_boolean:
name: No Motion Chooser (Optional)
description: Desired state of no motion blocker, choose on for on and off for
off
default: false
selector:
boolean: {}
elevation_check:
name: Sun elevation check (Optional)
description: This is the angle between the sun and the horizon. Negative values
mean the sun is BELOW the horizon.
default: none
selector:
number:
min: -90.0
max: 90.0
unit_of_measurement: degrees
mode: slider
step: 1.0
scene_ambient:
name: Ambient Scene (Optional)
description: Scene for ambient state. Will be activated when no motion is detected.
default: scene.none
selector:
entity:
domain:
- scene
multiple: false
time_scene_ambient_start:
name: Ambient time frame start (Optional)
description: Time from which on ambient scene will be activated
default: 00:00:00
selector:
time: {}
time_scene_ambient_end:
name: Ambient time frame end (Optional)
description: Time from which on ambient scene will be not activated
default: 00:00:00
selector:
time: {}
scene_morning:
name: Scene for the morning (Optional)
default: scene.none
selector:
entity:
domain:
- scene
multiple: false
time_scene_morning:
name: Time for the morning scene (Optional)
description: A time input which defines the time from which on the scene will
be activated if motion is detected.
default: 00:00:00
selector:
time: {}
scene_day:
name: Scene for the bright day (Optional)
default: scene.none
selector:
entity:
domain:
- scene
multiple: false
time_scene_day:
name: Time for the day scene (Optional)
default: 00:00:00
selector:
time: {}
scene_evening:
name: Scene for the evening (Optional)
default: scene.none
selector:
entity:
domain:
- scene
multiple: false
time_scene_evening:
name: Time for the evening scene (Optional)
default: 00:00:00
selector:
time: {}
scene_night:
name: Scene for the dark night (Optional)
default: scene.none
selector:
entity:
domain:
- scene
multiple: false
time_scene_night:
name: Time for the night scene (Optional)
be activated if motion is detectedd.
default: 00:00:00
selector:
time: {}
scene_no_motion:
name: Default scene for no motion (Optional)
description: Set this Scene if you want to activate a scene if motion stops
default: scene.none
selector:
entity:
domain:
- scene
multiple: false
mode: restart
max_exceeded: silent
variables:
scene_ambient: !input scene_ambient
scene_morning: !input scene_morning
scene_day: !input scene_day
scene_evening: !input scene_evening
scene_night: !input scene_night
automation_blocker: !input automation_blocker
automation_blocker_boolean: !input automation_blocker_boolean
no_motion_blocker: !input no_motion_blocker
no_motion_blocker_boolean: !input no_motion_blocker_boolean
elevation_check: !input elevation_check
scene_no_motion: !input scene_no_motion
motion_entity: !input motion_entity
- platform: state
entity_id: !input motion_entity
to: 'on'
- platform: state
to: 'off'
for: !input no_motion_wait
condition:
- condition: or
conditions:
- '{{ automation_blocker == none }}'
- '{{ automation_blocker_boolean and states[automation_blocker].state == ''on''
- '{{ not automation_blocker_boolean and states[automation_blocker].state == ''off''
- condition: template
value_template: '{{ (elevation_check == none) or (state_attr(''sun.sun'',''elevation'')
<= elevation_check | float(90)) }}'
- choose:
- conditions:
value_template: '{{ trigger.to_state.state == ''on'' }}'
sequence:
- choose:
- conditions:
- '{{ scene_morning != ''scene.none''}}'
- condition: time
after: !input time_scene_morning
before: !input time_scene_day
sequence:
- scene: !input scene_morning
- conditions:
- '{{ scene_day != ''scene.none''}}'
- condition: time
after: !input time_scene_day
before: !input time_scene_evening
sequence:
- scene: !input scene_day
- conditions:
- '{{ scene_evening != ''scene.none''}}'
- condition: time
after: !input time_scene_evening
before: !input time_scene_night
sequence:
- scene: !input scene_evening
- conditions:
- '{{ scene_night != ''scene.none''}}'
- condition: time
after: !input time_scene_night
before: !input time_scene_morning
sequence:
- scene: !input scene_night
default:
- service: light.turn_on
target: !input light_target
- conditions:
value_template: '{{ trigger.to_state.state == ''off'' }}'
- condition: or
conditions:
- '{{ no_motion_blocker == none }}'
- '{{ no_motion_blocker_boolean and states[no_motion_blocker].state == ''on''
- '{{ not no_motion_blocker_boolean and states[no_motion_blocker].state == ''off''
sequence:
- choose:
- conditions:
- '{{ scene_ambient != ''scene.none'' }}'
- condition: time
after: !input time_scene_ambient_start
before: !input time_scene_ambient_end
sequence:
- scene: !input scene_ambient
- conditions:
- '{{ scene_no_motion != ''scene.none'' }}'
sequence:
- scene: !input scene_no_motion
default:
- service: light.turn_off
You are using a blueprint, which is fine, but that also means that all of the actions are in the blueprint and it is the actions you have to change. I do not recommend a rookie take on changing a blueprint.
That means to do something custom you would need to draw out on paper what things you want to do and the order you want them to happen, and write the automation yourself.
