Apple does not share information on Items (only Persons and Devices): with the iCloud integration you not get the position.
So you need an Apple device with FindMy to track them (the application caches the coordinates on disk)
I then use FindMySync to push this cached information to Home Assistant (FindMySync - Martin Pham). It will automatically generate entries for known_devices.yml as
You will have to add attributes “latitude”, “longitude” to these history-stats sensors via customization - then just add these sensors on a map with this option “label_mode = state”.
Since zone entities should be also added on a map to display a “circle” - you will have to:
Specify a blank icon for each zone (mdi:blank).
Add those HS-sensors after zone entities - to make these sensors be shown ABOVE zones.
So I have a bunch of Thirdreality zigbee motion sensors around the house…
I’d love to create a similar heatmap for the most frequent activity areas in the house. Has anyone done this and can stare me in the right direction?
maybe not good for neighborhood birds, but if the cat has front claws, and you don’t live on a street with lots of traffic, roaming is the best thing for a cat. When i lived in an area that this was ok my cats would leave the heads of mice/birds all the time at the doorstep. That’s love right there.
