Base on the official blueprint and this Turn on light, switch, scene, script or group based on motion and illuminance (+ more conditions).
I write my first blueprint script cause I need to detect both motion and light sensor, and I
do not want to create too many help elements.
blueprint:
name: Motion and illuminance activated Light/Switch
description: Turn on a light or switch based on motion and illuminance.
domain: automation
source_url: https://community.home-assistant.io/t/motion-illuminance-switch/296450
input:
motion_entity:
selector:
entity:
domain: binary_sensor
device_class: motion
turn_on_target:
selector:
entity: {}
turn_off_target:
description: In general, the turn-on and turn-off target should be the same.
selector:
entity: {}
illuminance_sensor:
name: (OPTIONAL) Illuminance sensor
description: This sensor will be used to determine the illumination.
default:
selector:
entity:
domain: sensor
device_class: illuminance
illuminance_cutoff:
name: (OPTIONAL) Illuminance cutoff value
description: This input_number will be used to compare to the current illumination
to determine if it is low.
default: 0
selector:
number:
min: 0
max: 10000
step: 1
unit_of_measurement: lux
mode: slider
time_after:
name: Run after time.
default: '00:00:00'
selector:
time: {}
time_before:
name: Run before time.
default: '23:59:59'
selector:
time: {}
no_motion_wait:
description: Time to leave the target on after last motion is detected.
default: 3
selector:
number:
min: 0.5
max: 360.0
step: 0.5
unit_of_measurement: minutes
mode: slider
mode: restart
max_exceeded: silent
variables:
turn_on_target: !input 'turn_on_target'
illuminance_sensor: !input 'illuminance_sensor'
illuminance_cutoff: !input 'illuminance_cutoff'
platform: state
entity_id: !input 'motion_entity'
to: 'on'
condition:
- condition: time
after: !input 'time_after'
before: !input 'time_before'
- condition: or
conditions:
- "{{ is_state(turn_on_target,'on') }}"
- "{{ illuminance_cutoff|int == 0 }}"
- "{{ illuminance_sensor != None and (states(illuminance_sensor)|int < illuminance_cutoff|int) and (states(illuminance_sensor)!= 'unavailable') }}"
- alias: Turn on the target
service: homeassistant.turn_on
- alias: Wait until there is no motion from device
wait_for_trigger:
platform: state
to: 'off'
- alias: Wait the number of seconds that has been set
delay:
minutes: !input 'no_motion_wait'
- alias: Turn off the target
service: homeassistant.turn_off
target: !input 'turn_off_target'
