Rather new to Home Assistant and Node Red. I’ve been importing flows into Node red, and ended up with several “Servers.” I’m trying to collapse them into one. I named the one I’m using to Home Assistant Real just to distinguish it from the rest. I made sure that the server selection for allitems in the flow are set to home assistant real. The problem, i think, is that the edit change node is not referencing this server. I’m not 100% sure this is the issue. Hpoing someone can take a quick look and help. The motion lights work fine, and turn the lights on at the appropriate brightness for the time of day. The problem is that when i have automation set to off, the motion lights are still triggered. Thanks for anyones help.
[{"id":"af8612f417bce48b","type":"comment","z":"2f95c855cb2cd6a6","name":"Parker","info":"","x":110,"y":2780,"wires":[]},{"id":"9fdc28cbbe44dc42","type":"server-state-changed","z":"2f95c855cb2cd6a6","name":"Motion","server":"9405c3fe.d0a6c","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.parker_motion_sensor_ias_zone","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":2920,"wires":[["6edd805c997c7f6d"]]},{"id":"6edd805c997c7f6d","type":"change","z":"2f95c855cb2cd6a6","name":"Get input_boolean state and set delays in ms","rules":[{"t":"set","p":"delay","pt":"msg","to":"$globalContext(\"homeassistant.homeAssistant.states['input_boolean.parker_automation'].state\")","tot":"jsonata"},{"t":"change","p":"delay","pt":"msg","from":"on","fromt":"str","to":"300000","tot":"num"},{"t":"change","p":"delay","pt":"msg","from":"off","fromt":"str","to":"1800000","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":215,"y":2920,"wires":[["c8216a4ce8da120c"]],"l":false},{"id":"659336d110a29471","type":"trigger","z":"2f95c855cb2cd6a6","name":"","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"250","extend":false,"overrideDelay":true,"units":"ms","reset":"on","bytopic":"all","topic":"topic","outputs":1,"x":535,"y":2980,"wires":[["4e38033a0db12a31"]],"l":false},{"id":"c8216a4ce8da120c","type":"switch","z":"2f95c855cb2cd6a6","name":"Automation on or off?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":360,"y":2920,"wires":[["659336d110a29471","cd867336755e02a4","18a5509c0b901c38"],["659336d110a29471"]]},{"id":"4e38033a0db12a31","type":"api-call-service","z":"2f95c855cb2cd6a6","name":"Light off","server":"bb06732d.30845","version":3,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.parker_ceiling_fan, fan.parker_ceiling_fan","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":640,"y":2980,"wires":[["b58a3cce547a8f3a"]]},{"id":"b58a3cce547a8f3a","type":"api-current-state","z":"2f95c855cb2cd6a6","name":"Input off?","server":"9405c3fe.d0a6c","version":2,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.parker_automation","state_type":"str","blockInputOverrides":true,"outputProperties":[],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":880,"y":2980,"wires":[["cfb7902164d0498a"],[]]},{"id":"cfb7902164d0498a","type":"api-call-service","z":"2f95c855cb2cd6a6","name":"Input on","server":"9405c3fe.d0a6c","version":3,"debugenabled":false,"service_domain":"homeassistant","service":"turn_on","entityId":"input_boolean.parker_automation","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1030,"y":2980,"wires":[[]]},{"id":"cd867336755e02a4","type":"api-current-state","z":"2f95c855cb2cd6a6","name":"Day?","server":"9405c3fe.d0a6c","version":2,"outputs":2,"halt_if":"Day","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.time_of_day","state_type":"str","blockInputOverrides":false,"outputProperties":[],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":570,"y":2840,"wires":[["f1d8aea6165f32f3"],[]]},{"id":"f1d8aea6165f32f3","type":"api-call-service","z":"2f95c855cb2cd6a6","name":"Light 100%","server":"bb06732d.30845","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.parker_ceiling_fan","data":"{\"brightness_pct\": \"100\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":770,"y":2820,"wires":[[]]},{"id":"217876d8abf96aae","type":"api-call-service","z":"2f95c855cb2cd6a6","name":"Light 20%","server":"bb06732d.30845","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.parker_ceiling_fan","data":"{\"brightness_pct\": \"20\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":770,"y":2900,"wires":[[]]},{"id":"18a5509c0b901c38","type":"api-current-state","z":"2f95c855cb2cd6a6","name":"Evening?","server":"9405c3fe.d0a6c","version":2,"outputs":2,"halt_if":"Evening","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.time_of_day","state_type":"str","blockInputOverrides":false,"outputProperties":[],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":580,"y":2900,"wires":[["217876d8abf96aae"],[]]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"bb06732d.30845","type":"server","name":"Home Assistant","version":1,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true}]
