Motion light sensor is not allowing to read Lux value?
Hi.
I’m using this device: TuYa ZG-204ZL control via MQTT | Zigbee2MQTT
Which exposes Lux value but it’s not possible to read (/get) the value?
In this case, how can I utilize the Lux value to automate based on illuminance and motion?
As discussed on Discord:
  1. You can’t read from end devices, that’s normal
  2. You have an entity for that
  3. You’ve said that the entity isn’t available
  4. You need to wait for the entity to report after you’ve started HA, or you need to have retain set
Hi, I wanted to ask if it was possible to add the lux value on the Tuya ZG-204ZL sensor (3towulqd) in the Tuya integration. As it is only possible to see it if you use ZHA integration.
Thank you
