Motion Lighting by House Mode Blueprint
Motion-activated lighting that automatically adjusts brightness based on your house mode (Day, Evening, Night).
House mode is optional — leave blank for simple full-brightness motion lighting (perfect for laundry rooms, garages, etc.).
:sparkles: Key Features
  • Adaptive Brightness: Day (100%), Evening (20%), Night (10%) — fully configurable
  • House Mode Optional: Leave blank → uses Day brightness as default
  • Enable/Disable Toggle: Optional input_boolean with auto re-enable timer
  • Per-Mode Disable: Turn off motion lighting in specific modes (Day, Evening, Night)
  • Multiple Zones: Create separate instances for different rooms
  • Auto-Off Timer: Configurable minutes after no motion
:play_button: Import the blueprint
Open your Home Assistant instance and show the blueprint import dialog with a pre-filled URL to import this blueprint.
If the button doesn’t work, copy this URL and paste into Settings → Automations & Scenes → Blueprints → Import Blueprint:
https://raw.githubusercontent.com/curfew3749/home-assistant-blueprints/refs/heads/main/motion_lighting_by_house_mode.yaml
