Motion Lights, please help
Hi All,
New to home assistant.
I can’t get this automation working. I have a shelly switch and the aqara motion sensor. I think its something to do with the YAML as the switch and sensor work independently. Any ideas. Photos attached.
I wrote the script written but when I saved it changed automatically.
Script in at the moment is
triggers:
  - entity_id: binary_sensor.0x54ef441000b6309c_occupancy
    to: "on"
    trigger: state
    to: "off"
    for:
      minutes: 2
    trigger: state
actions:
  - target:
      entity_id: switch.en_suite_light_switch_0
    action: light.turn_{{ trigger.to_state.state }}
mode: single
Please read this from How to help us help you - or How to ask a good question → 11 Format it properly
Sorry about that Nick,
Just updated now
Thanks in advance
Did you check the traces of the automation?
Also, I would advice you to give your devices/entities a much more meaningful name then
0x54ef441000b6309c to make things easier to recognize/read/troubleshoot.
In the automation I can see when I move infront of the sensor it triggers.
Its just the action (Then do) that isn’t working
Is the entity_id correct?
Also: put double quotes around it.
entity_id is correct and double quotes didn’t help.
The error i’m getting when trying to run the action is this
“Error rendering service name template: UndefinedError: ‘trigger’ is undefined”
Sadly not.
This is the code
triggers:
    to: "on"
    trigger: state
  - entity_id:
      - binary_sensor.0x54ef441000b6309c_occupancy
    to: "off"
    for:
      hours: 0
      minutes: 0
      seconds: 1
    trigger: state
actions:
  - target:
    action: light.turn_{{ "trigger.to_state.state" }}
mode: single
and get the error “Template rendered invalid service: light.turn_trigger.to_state.state”
Sorry if this an easy fix but this is all new to me haha
Changed to one second at the moment for troubleshooting
Shouldn’t that be
switch.turn_{{ "trigger.to_state.state" }}
No joy with that.
with this
action: turn.switch_{{ trigger.to_state.state }}
getting this error when trying to run action “Error rendering service name template: UndefinedError: ‘trigger’ is undefined”
Of course: you have to give both triggers an ID: click on the dots and name them on & off
Yeah this was it.
Thanks for your help
