This blueprint: https://gist.github.com/dirkk1980/3e5c23acb05fb639bafdc5036b91aae6 have what I want, but I don’t want scenes but change brigthness.
Im new to home assistant and yaml but I tried to make it:
blueprint:
name: Motion-activated light scene with surrounding light level check and optional ambient scene
description: Turn on a light scene when motion is detected. Three different scenes can be defined depending on time of day. Furthermore a source for checking sourrounding light can be defined to enable light only if it is dark enough.
domain: automation
source_url: https://gist.github.com/dirkk1980/3e5c23acb05fb639bafdc5036b91aae6
input:
motion_entity:
selector:
entity:
domain: binary_sensor
device_class: motion
lightsensor_entity:
selector:
entity:
domain: sensor
device_class: illuminance
illuminace_level:
name: Max Illuminance
description: Maximal immuminance level in lux. If illuminance is higher, light will not be enabled
default: 600
selector:
number:
min: 0
max: 5000
unit_of_measurement: lux
light_target:
selector:
entity:
domain: light
scene_ambient:
name: Ambient Scene (Optional)
description: Scene for ambient state. Will be activated when no motion is detected and light level is under threshold. Default value = scene.none
default: 2
selector:
number:
min: 1.0
max: 100.0
step: 1.0
mode: slider
time_scene_ambient_start:
name: Ambient time frame start
description: Time from which on ambient scene will be activated
default: "00:00:00"
selector:
time:
time_scene_ambient_end:
name: Ambient time frame end
description: Time from which on ambient scene will be not activated
default: "00:00:00"
selector:
time:
scene_morning:
name: Scene for the morning
default: 100
selector:
number:
min: 1.0
max: 100.0
step: 1.0
mode: slider
time_scene_morning:
name: Time for the morning scene
description: A time input which defines the time from which on the scene will be activated if motion is detected. Default value = scene.none
default: "00:00:00"
selector:
time:
scene_day:
name: Scene for the bright day
default: 80
selector:
number:
min: 1.0
max: 100.0
step: 1.0
mode: slider
time_scene_day:
name: Time for the day scene
default: "00:00:00"
selector:
time:
scene_evening:
name: Scene for the evening
default: 50
selector:
number:
min: 1.0
max: 100.0
step: 1.0
mode: slider
time_scene_evening:
name: Time for the evening scene
default: "00:00:00"
selector:
time:
scene_night:
name: Scene for the dark night
default: 1
selector:
number:
min: 1.0
max: 100.0
step: 1.0
mode: slider
time_scene_night:
name: Time for the night scene
description: A time input which defines the time from which on the scene will be activated if motion is detectedd. Default value = scene.none
default: "00:00:00"
selector:
time:
no_motion_wait:
description: Time to leave the light on after last motion is detected.
default: 120
selector:
number:
min: 0
max: 3600
unit_of_measurement: seconds
mode: restart
max_exceeded: silent
variables:
scene_ambient: !input scene_ambient
platform: state
entity_id: !input motion_entity
to: "on"
## condition for illumination has to be checked for every scece and not global. reason: action should be also triggered if no lights should be enabled to switch off ambient scene if it is to bright
- choose:
- conditions:
- condition: time
after: !input time_scene_morning
before: !input time_scene_day
- condition: numeric_state
entity_id: !input lightsensor_entity
below: !input illuminace_level
sequence:
- alias: "lights on"
service: light.turn_on
entity_id: !input light_target
brightness: !input scene_morning
- conditions:
- condition: time
after: !input time_scene_day
before: !input time_scene_evening
sequence:
brightness: !input scene_day
- conditions:
- condition: time
after: !input time_scene_evening
before: !input time_scene_night
sequence:
brightness: !input scene_evening
- conditions:
- condition: time
after: !input time_scene_night
before: !input time_scene_morning
sequence:
brightness: !input scene_night
- wait_for_trigger:
platform: state
to: "off"
- delay: !input no_motion_wait
- choose:
- conditions:
- "{{ scene_ambient != 'scene.none'}}"
- condition: time
after: !input time_scene_ambient_start
before: !input time_scene_ambient_end
sequence:
brightness: !input scene_ambient
default:
- service: light.turn_off
target: !input light_target
It doens’t work i get this ERROR:
2021-08-28 14:11:06 ERROR (MainThread) [homeassistant.components.automation] Blueprint Motion-activated light scene with surrounding light level check and optional ambient scene generated invalid automation with inputs OrderedDict([('motion_entity', 'binary_sensor.badkamer_beweging'), ('lightsensor_entity', 'sensor.badkamer_lx'), ('light_target', OrderedDict([('device_id', '297b0313ce1a9a5bbebfc918bc963a35')])), ('scene_morning', 85), ('scene_evening', 54), ('scene_day', 90), ('illuminace_level', 324), ('time_scene_morning', '10:00:00'), ('time_scene_day', '12:00:00'), ('time_scene_evening', '13:00:00'), ('time_scene_night', '14:00:00')]): not a valid value for dictionary value @ data['action'][0]['choose'][0]['sequence'][0]['target']['entity_id']. Got None
What do I wrong?
