Motion sensor detection interval does not update
Hi, yesterday I installed my new SkyConnect and an Aqara motion sensor P1. But when i try to change de Detection Interval from 30 to another value, it doesn’t update. Same problem with changing the Motion Sentivity and the LED trigger indicator. The log says:
‘2023-02-02 19:14:40.733 ERROR (MainThread) [homeassistant.components.zha.entity] number.lumi_lumi_motion_ac02_detection_interval: Could not set value: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>’
‘2023-02-02 19:14:44.192 ERROR (MainThread) [homeassistant.components.zha.entity] switch.lumi_lumi_motion_ac02_led_trigger_indicator: Could not set value: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>’
‘2023-02-02 19:14:48.784 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139834351765536] Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>’
I don’t know how to solve this problem. Can anybody help?
Pim
To change those settings, you need to press the button on the device first. You then get (I think) 30 seconds to make those settings changes before they are locked in.
This also happens when you first pair it, so you might have found you could change them when you first installed it, but didnt appear to be able to afterwards.
