blueprint:
name: Motion Sensor Inactivity Automation with Sun Condition
description: If one or more motion sensors have not detected movement for a specified
number of hours and the sun is up or down, close a cover and turn off lights and
climate control.
domain: automation
input:
motion_sensor_entities:
description: The entity IDs of the motion sensors to monitor for inactivity.
If any of the sensors have not detected motion for the specified number of
hours, the automation will trigger.
selector:
entity:
domain:
- binary_sensor
device_class:
- motion
multiple: true
cover_entity:
description: The entity ID of the cover to close when motion sensor is inactive
for the specified number of hours.
default: {}
selector:
entity:
domain:
- cover
multiple: false
light_entities:
description: The entity IDs of the lights to turn off when motion sensor is
inactive for the specified number of hours.
selector:
entity:
domain:
- light
multiple: true
climate_entity:
description: The entity ID of the climate control to turn off when motion sensor
is inactive for the specified number of hours.
selector:
entity:
domain:
- climate
multiple: false
sun_condition:
name: Sun Condition
description: When to run the automation - "above_horizon" for when the sun is
up, "below_horizon" for when the sun is down, or "ignore" to run regardless
of sun condition.
selector:
select:
options:
- ignore
- above_horizon
- below_horizon
custom_value: false
multiple: false
inactivity_hours:
description: The number of hours of inactivity to trigger the automation.
default: 1
selector:
number:
min: 1.0
max: 24.0
step: 1.0
unit_of_measurement: hours
mode: slider
source_url: https://community.home-assistant.io/t/motion-sensor-inactivity-automation/561600
mode: single
- platform: state
entity_id: !input motion_sensor_entities
to: 'off'
for:
hours: !input inactivity_hours
variables:
light_entities: !input light_entities
climate_entity: !input climate_entity
cover_entity: !input cover_entity
sun_condition: !input sun_condition
condition:
- condition: template
value_template: "{{ (sun_condition == 'ignore') or ((sun_condition == 'above_horizon'
and states.sun.sun.state == 'above_horizon') or (sun_condition == 'below_horizon'
and states.sun.sun.state == 'below_horizon')) }}"
- choose:
- conditions: '{{ light_entities|length > 0 }}'
sequence:
- service: light.turn_off
entity_id: !input light_entities
- choose:
- conditions: '{{ climate_entity|length > 0 }}'
sequence:
- service: climate.turn_off
entity_id: !input climate_entity
- choose:
- conditions: '{{ cover_entity|length > 0 }}'
sequence:
- service: cover.close_cover
entity_id: !input cover_entity
Thanks for sharing! Would you mind to tell us something about your own intention of building this blueprint? What was the purpose?
BR
André
